Or when it gets a connection disconnected.: Even if its in a parallell block.
- action: notify.notify
metadata: {}
title: '{{ title if title != "" else " "}}'
message: '{{ message if message != "" else " "}}'
alias: Global
- alias: Pushbullet
choose:
- conditions:
- condition: template
value_template: '{{ pushbullet }}'
sequence:
- data:
action: notify.pushbullet
continue_on_error: true
2024-10-27 14:25:16.524 ERROR (MainThread) [homeassistant.components.script.notifying_multiple_devices] Notifying multiple devices: Parallel action at step 1: parallel 7: Pushbullet: choice 1: Error executing script. Unexpected error for call_service at pos 1: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 716, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 468, in _make_request
six.raise_from(e, None)
File "", line 3, in raise_from
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 463, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.12/http/client.py", line 1428, in getresponse
response.begin()
File "/usr/local/lib/python3.12/http/client.py", line 331, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.12/http/client.py", line 300, in _read_status
raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 667, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 802, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.12/site-packages/urllib3/util/retry.py", line 552, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.12/site-packages/urllib3/packages/six.py", line 769, in reraise
raise value.with_traceback(tb)
response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 525, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 763, in _async_call_service_step
response_data = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 726, in _async_run_long_action
return await long_task
File "/usr/src/homeassistant/homeassistant/core.py", line 2761, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2804, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/components/notify/legacy.py", line 273, in _async_notify_message_service
await self.async_send_message(**kwargs)
File "/usr/src/homeassistant/homeassistant/components/notify/legacy.py", line 251, in async_send_message
await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/pushbullet/notify.py", line 77, in send_message
self._push_data(message, title, data, self.pushbullet)
File "/usr/src/homeassistant/homeassistant/components/pushbullet/notify.py", line 157, in _push_data
pusher.push_note(**kwargs)
File "/usr/local/lib/python3.12/site-packages/pushbullet/pushbullet.py", line 286, in push_note
return self._push(data)
File "/usr/local/lib/python3.12/site-packages/pushbullet/pushbullet.py", line 304, in _push
r = self._session.post(self.PUSH_URL, data=json.dumps(data))
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 637, in post
return self.request("POST", url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 589, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 703, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 682, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
2024-10-27 14:25:16.682 DEBUG (SyncWorker_13) [homeassistant.components.pushbullet.notify] Sent notification to self
2024-10-27 14:25:16.691 ERROR (MainThread) [homeassistant.components.script.notifying_multiple_devices] Notifying multiple devices: Parallel action at step 1: parallel 7: Error executing script. Unexpected error for choose at pos 1: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
response.begin()
response.begin()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1048, in _async_choose_step
await self._async_run_script(script)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1268, in _async_run_script
result = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1795, in async_run
return await asyncio.shield(create_eager_task(run.async_run()))
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 463, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 527, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 580, in _handle_exception
raise exception
