I currently have a script that perform a series of task to “close” the house when leaving, as shutting down all the lights, locking the door and activating the alarm. Sometimes some of these calls fail and I leave home half open (mostly nuki lock). I was really happy reading in the last update about the introduction of the “continue on error” function HERE and applied it to the relevant actions, for example:
I know the script stops there from the trace, I just cannot post an example because at every reboot I lose the script debug logs.
The Nuki integration throws an error and it doesn’t continue…
For me also is not working with Error: http status: 404, code:-1 - https://api.spotify.com/v1/me/player/play?device_id=blablas: Device not found, reason: None
I’m not familiar with Docker so I search through Google - 22222 Dev Shell and find this add on:
May I ask if I will install that one I can connect and edit above lines?
If yes, how to ssh? Like my HA IP and 22222 port via Putty?
You still need to know how to generate SSH key pair, use a terminal and vi.
I don’t recommend fiddling with the code if you are not completely sure about what you are doing. Any wrong change can brick your HA and any change will be lost after updating HA anyway.
It’s not my first time messing with the code.
I’m familiar with the SSH and SSH keys but I’m not sure about this part of the configuration. I don’t have any interface for entering the key.
Hey, any luck with this yet? I have exactly the same problem with the error 503 with the Nuki lock and wanted to use continue_on_error but I’m a bit hesitant if I read your post…
The problem is that the TV goes from available to unavailable like every minute (yeah, philipls suck and i don’t want to talk about it), so the automation is stopped when this command is performed and the TV happens to be unavailable:
As you can see from the first image, the continue on error is set to true, so i really don’t see why the automation still stops.
And really, it doesn’t matter why the TV becomes unavailable, if there is such an option in the automation it MUST work
