After a few days working on unrelated tasks, I am back to configuration my HA installation.
I added the Wemo details as suggested in my previous post. This was during my first run, HA had not been restarted at that point. After restart, I got a window came up on my web view saying Invalid Config and listing history, recorder and logbook as culprits. Also the log was missing from the lefthand pane.
check_config ran clean. I checked the link on logbook and what was in the file was exactly as described.
I restored the original yaml file and exactly the same.
Now I am trying to add Open Weather Map. I have an API key and have followed descriptions found on the HA site, my entry looking like this, though with my API key, which I have withheld from this post:-
check_config reports:-
2018-01-24 10:51:27 ERROR (Thread-2) [homeassistant.util.yaml] mapping values are not allowed here
in â/home/homeassistant/.homeassistant/configuration.yamlâ, line 79, column 14
Line 79 being the one with the API key.
Does anyone have any ideas what is happening here?
Why are you not trying to determine what the original error is rather than adding more to make an even bigger can of worms? Please show us the config sans personal details (use the CODE Blocks, so paste it in here then make sure there is a blank line above and below it, then select it and hit the </> in the edit box - this preserves the spacing - very important in yaml).
Iâm not sure if you wanted the complete file, but this is the contents of the original file, which on first start gave no error report on the web page and gave me a link to the logfile on the left.
Second and subsequent starts all have this Invalid Config block on the web page, even if I restore the original file.
The complete contents of the original file are listed below. I have checked all blank lines to ensure they are blank with no spurious characters. history and logfile appear correct, no reference to record, though it does complain.
Sorry, canât get it to copy in without changing the format, but I have checked all blank lines are blank.
It shouldnât make any difference, but I use vi to edit the yaml file.
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude:
longitude:
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation:
# metric for Metric, imperial for Imperial
unit_system: imperial
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/Los_Angeles
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
# Secrets are defined in the file secrets.yaml
# api_password: !secret http_password
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
There is a deps directory, but with zero content. I renamed this directory and without it, HA gave an error when trying to start. I have now restored it.
The Open Weather contents were as follows. The error refers to the start of my API key, which when entered in the file is the true key which I have hidden here.
Thanks, I am running clean on check_config now, I see the error, being the api_key line and following being too far indented. I actually copied that block from some other post, maybe they were complaining about the same thing, but I should have spotted the indent error.
So still have the Invalid Config block showing on the web page, that is with the empty deps directory back in place.
I donât think you have posted the logs for the invalid config block yet? TBH I would put recorder in as Iâm pretty sure that logbook/history wonât work without it.
Where would I find that, on first start I had a link on the left and used the log there to confirm the IP addresses form my wemo devices, but I donât have a link any more. Where are these logs written?
It was the default, but I added these lines. Still clean on check_config, but no change going through a stop/start cycle. Should they be in any particular order?
Righty ho, I refuse to let this beat me. Delete the entire contents of your configuration.yaml
Copy and paste this in.
Scroll down to the openweathermap bit and put your api_key in.
Save.
Restart.
Let me know
homeassistant:
latitude:
longitude:
elevation:
introduction:
frontend:
config:
http:
updater:
discovery:
conversation:
history:
logbook:
recorder:
purge_interval: 3
purge_keep_days: 7
map:
# Track the sun
sun:
- platform: yr
- platform: openweathermap
api_key: MY_API_KEY
name: Aliso Viejo Weather
forecast: true
monitored_conditions:
- weather
- temperature
- wind_speed
- wind_bearing
- humidity
- pressure
- clouds
- rain
# Text to speech
tts:
- platform: google
# Cloud
cloud:
