Continuous 30 min average
Hi
I have, in my opinion, simple need, which does not seem to have a simple implementation:
Scenario: When the average wattage draw over the last 30 minutes is below threshold, switch off.
I encoutered the site templating yet it seems a bit of an overkill to me - is there a simpler way to achieve this?
If you could point me in the direction of “simplicity”, I would be greatful.
thx
Use time moving simple average
there is also an “average” sensor available in HACS that I use for pretty much the same use case (turn off a battery charger when the average power is below a value) and it works well.
Hi
Thanks for the help. I discovered the trigger on numeric_state which has a timer… It does not calculate the average but when the threshold is a bit higher to include peaks, it should work too.
 - platform: numeric_state
    entity_id: sensor.schalt_mess_steckdose_power
    for:
      hours: 0
      minutes: 20
      seconds: 0
    below: 75
Not sure why I missed this one the first time…
Thank you anyway!
Be aware that if you restart HA at any time in that 20 minute window the automation will not run.
I never use delay, for, etc in HA for longer than 5 minutes (acceptable fault tolerance) for anything that is important.
Wow what an interesting integration!! thanks PeteRage!
The caveat on non-time based windows coupled with longer retention periods is well noted!
