Looking for some assistance in creating a series of cards; based on which docker containers are running, then showing a container specific card for each.
I believe I need to use a combination of custom:auto-entities
& custom:card-templater
; I’m just honestly not sure how to iterate through the running containers dynamically. So if a new container gets added, so does a new set of cards.
Each container should have the following config
type: vertical-stack
cards:
- type: custom:multiple-entity-row
entity: sensor.jabba_adguard_status
secondary_info: last-changed
- type: custom:bar-card
entities:
- entity: sensor.jabba_adguard_cpu
positions:
minmax: inside
animation:
state: on
- entity: sensor.jabba_adguard_memory
positions:
minmax: inside
animation:
state: on
color: var(--secondary-color)
The variables here would be “title”, and “entity”. The entities will always be in format sensor.jabba_$name_cpu
, sensor.jabba_$name_memory
or sensor.jabba_$name_status
Just not sure how to iterate through all running containers.
Any help would be greatly appreciated.
Cheers
