For use with a Zooz ZEN32 Scene Controller.
Lets you use one of the buttons on the controller mimicking the behavior of some of their dedicated light switches.
- Tap button to toggle on/off
- Hold button for night light
- Double-tap for full brightness
I like to use this in the open area in my house to have the big button control a group of all lights while the smaller buttons can control individual ones.
I recommend using this in conjunction with my automation that sets the LED indicator on the buttons based on the state of your light entity:
Set the Indicator Light on a Zooz ZEN32 Scene Controller button to Match the State of a Light
blueprint:
name: Control Light with Scene Controller
description: For Zooz ZEN32. Toggle a light with a single press, set it to max brightness with double-tap, night-light mode with hold.
domain: automation
input:
zooz_switch:
description: List of available Zooz ZEN32 switches.
selector:
device:
filter:
- integration: zwave_js
manufacturer: Zooz
model: ZEN32
manufacturer: Zooz
model: "ZEN32 800LR"
target_light:
description: The light to link to button
selector:
entity:
domain: light
scene_button:
description: The button to link to light
selector:
select:
mode: dropdown
options:
- label: Scene 5 (Big Button)
value: '005'
- label: Scene 1 (Top Left)
value: '001'
- label: Scene 2 (Top Right)
value: '002'
- label: Scene 3 (Bottom Left)
value: '003'
- label: Scene 4 (Bottom Right)
value: '004'
night_light_brightness:
name: Night Light Brightness
description: Brightness to set lights to when button is held (default 20%)
default: 20
selector:
number:
min: 0
max: 100
unit_of_measurement: "%"
mode: single
max_exceeded: silent
variables:
controller_id: !input 'zooz_switch'
light_id: !input 'target_light'
button_id: !input 'scene_button'
night_light_brightness: !input 'night_light_brightness'
- platform: event
event_type: zwave_js_value_notification
condition: '{{ trigger.event.data.device_id == controller_id and trigger.event.data.property_key_name == button_id }}'
- variables:
property_key_name: '{{ trigger.event.data.property_key_name }}'
label: '{{ trigger.event.data.label }}'
command_class_name: '{{ trigger.event.data.command_class_name }}'
value: '{{ trigger.event.data.value }}'
- service: logbook.log
message: 'received event: {{ command_class_name }} - {{ value }} - {{ label }}'
- choose:
- conditions: '{{ value == ''KeyPressed'' }}'
sequence:
- service: light.toggle
data: {}
target: !input 'target_light'
- conditions: '{{ value == ''KeyPressed2x'' }}'
sequence:
- service: light.turn_on
brightness_pct: 100
- conditions: '{{ value == ''KeyHeldDown'' }}'
sequence:
brightness_pct: '{{ night_light_brightness }}'
