Hello HA community!
My question is about, how to control a Philips Hue bulp with a hardware switch and a hardware potentiometer.
The hardware switch should switch the lights on/off and the hardware potentiometer should control HUE, SAT and BRT.
On HA side I found the Philips Hue bulb in Settings > Devices & Services > Entities (entity.ID: “light.f”).
There directly and as well with an additonal switch on the dashboard I can control this bulp for on/off, brightness, colour temperature, etc. .
No issues.
On ESP8266 side I have a hardware switch and a hardware potentiometer.
The MQTT client (running on a Wemos D1 mini) publishes following values:
mqttClient.publish("/Bathroom/Light/HUE", String(PotiHUE).c_str()); //Example value: 110
mqttClient.publish("/Bathroom/Light/SAT", String(PotiSAT).c_str()); //Example value: 150
mqttClient.publish("/Bathroom/Light/BRT", String(PotiBRT).c_str()); //Example value: 180
if...
mqttClient.publish("/Bathroom/Light/Upper", "OFF");
if...
mqttClient.publish("/Bathroom/Light/Upper", "ON");
With the mosquitto of HA I receive the published topics and the values.
No issues.
I checked this HA documentation for “MQTT Lights”…
… and attached following code to my configuration.yaml:
#--- MQTT ---
mqtt:
light:
- name: "Bathroom Light"
unique_id: 'LED674'
state_topic: "/Bathroom/Light/Upper"
command_topic: "/Bathroom/Light/Upper"
brightness_state_topic: "/Bathroom/Light/BRT"
brightness_command_topic: "/Bathroom/Light/BRT"
rgb_state_topic: "/Bathroom/Light/HUE"
rgb_command_topic: "/Bathroom/Light/HUE"
state_value_template: "{{ value_json.state }}"
brightness_value_template: "{{ value_json.brightness }}"
rgb_value_template: "{{ value_json.rgb | join(',') }}"
qos: 0
payload_on: "ON"
payload_off: "OFF"
optimistic: false
In Setting > Devices & Services > Entities I find now this new entity “Bathroom Light” (entity.ID “light.b_light”).
With the hardware switch attached to the ESP8266 I can now “Bathroom Light” turn on and turn off.
So far so good.
My 1st issue is:
I can’t control the brightness and I can’t control the color temperature of “Bathroom Light” with the hardware potentiometer attached to the ESP8266.
Is this a topic of converting string in integer or something like that?
The 2nd issues is:
How do I connect “Bathroom Light” to the real Phlipps Hue bulp (entity.ID: “light.f”)?
I think I need some additional code to link both together, may be via the entity.ID?
I found some similar questions from other about this, but unfortunately I can’t bring this together to solve my issues.
Many thanks in advance!
