Hi!
I like this project! Previously I use HomeGenie to control my Network relays. I wrote the .NET program to control it. HA support TCP/IP network relays?
My relay: http://www.alphachn.com/products.asp?id=134
My .NET program code in HomeGenie:
Startup code:
Program.AddOption("IPAddress", "10.1.1.?", "0. Enter IP address of Network Relays", "text"); Program.AddOption("Port", "6000", "1. Enter port of Network relays", "text");
Program.AddVirtualModules(“HomeAutomation.NetworkRelays”, “Light”, “homegenie/generic/light”, 1, 8);
Program.Run();
Program code:
//Alpha Smart Home remote controller (8 relays)
var NetworkRelaysModules = Modules.InDomain(“HomeAutomation.NetworkRelays”);
Program.Parameter(“Status.Level”).Value = “1”;
string server = Program.Option(“IPAddress”).Value.Trim();
string port = Program.Option(“Port”).Value.Trim();
//Get status command
byte getstatus = new byte {85,170,170,170,170,170,0,1,47,215,22};
Action HandleStringReceived = (string message) => {
Program.Notify(“Server String”, message);
Action<byte> HandleMessageReceived = (byte message) => {
if ((message.Length == 17)&& message[6] == 128) //status message received
int value = message[14];
var relayarray = Convert.ToString(value, 2).PadLeft(8, ‘0’).ToArray();
for (int i=0;i<8;i++)
var module = NetworkRelaysModules.WithAddress((8-i).ToString()).Get();
// Relay status changed by wall switch (!=)
if ((module.Parameter(“Status.Level”).DecimalValue).ToString() != relayarray[i].ToString())
module.Toggle();
else
TcpClient.SendMessage(getstatus);
Action HandleStatusChanged = (bool connected) => {
Program.Notify(“TCP Client”, "Connected = " + connected);};
When.WebServiceCallReceived(“HomeAutomation.NetworkRelays”, ( args ) =>
string reqs = ((string)args).Split(‘/’);
var res = “{ ‘ResponseValue’ : ‘ERROR’ }”;
try
string switchnumber = reqs[1];
string command = reqs[2];
var module = NetworkRelaysModules.WithAddress(switchnumber).Get();
byte relayon = new byte {85,170,170,170,170,170,3,6,Convert.ToByte(127 + Convert.ToInt32(switchnumber)),0,0,0,0,0,Convert.ToByte(47 + Convert.ToInt32(switchnumber)),22};
byte relayoff = new byte {85,170,170,170,170,170,3,6,Convert.ToByte(143 + Convert.ToInt32(switchnumber)),0,0,0,0,0,Convert.ToByte(63 + Convert.ToInt32(switchnumber)),22};
switch(command)
case “Control.On”:
if (module.Parameter(“Status.Level”).Value != “1”)
Program.RaiseEvent(module, “Status.Level”, “1”, “NetworkRelays”);
TcpClient.SendMessage(relayon);
Pause(1);
res = “{ ‘ResponseValue’ : ‘OK’ }”;
break;
case “Control.Off”:
if (module.Parameter(“Status.Level”).Value != “0”)
Program.RaiseEvent(module, “Status.Level”, “0”, “NetworkRelays”);
TcpClient.SendMessage(relayoff);
Pause(1);
break;
case “Control.Toggle”:
if (module.Parameter(“Status.Level”).DecimalValue == 0)
Pause(1);
else
Pause(1);
break;
catch (Exception e)
Program.Notify(“HomeAutomation.NetworkRelays ERROR”, e.Message);
res = e.Message + " " + e.StackTrace;
return res;
TcpClient
.OnMessageReceived( HandleMessageReceived )
.OnStringReceived( HandleStringReceived )
.OnStatusChanged( HandleStatusChanged )
.Service( server );while (Program.IsEnabled)
if (!TcpClient.IsConnected)
if (!String.IsNullOrWhiteSpace(server) && !server.EndsWith(“?”) && !String.IsNullOrWhiteSpace(port))
TcpClient
.Connect( Convert.ToInt32(port) );} else { Program.Notify("Network Relays", "Please set valid IP address!"); } }
Pause(5);
Program.GoBackground();
Can anybody help to “convert” it to phyton? Unfortunately I am not a programmer.
Or if not, the HomeGenie can use MQTT. How can I use it with Home Assistant?!
Thanks for Your helps!
