Hi everyone,
I’m a new home assistant user, I’ve a little trouble in a gpio’s raspberry configuration.
So, I’ve a home assistant on a Raspberry pi 3B (hassos_rpi3 on it) and I want to control a relay (the relay control a lamp) wired on a second raspberry pin (Raspberry pi zero w). I want do this with MQTT.
I install mosquitto broker with the home assistant add-on on the RPI 3.
In the configuration.yaml :
#MQTT lampe
# Example configuration.yaml entry
light:
- platform: mqtt
state_topic: "office/light/status"
command_topic: "office/light/switch"
payload_off: "OFF"
brightness_state_topic: 'office/light/brightness'
brightness_command_topic: 'office/light/brightness/set'
on_command_type: 'brightness'
Source : https://www.home-assistant.io/integrations/light.mqtt/
On the RPI 0, I install pi-mqtt-gpio github (https://github.com/flyte/pi-mqtt-gpio)
In a configuration.yml file, I write :
mqtt:
host: my_ip_broker
port: 1883
user: "user"
password: "password"
topic_prefix: office/light
gpio_modules:
- name: raspberrypi
module: raspberrypi
digital_outputs:
- name: lights
module: raspberrypi
pin: 4
on_payload: "ON"
off_payload: "OFF"
initial: low
retain: yes
When I run this program, there are :
mqtt_gpio (INFO): Startup
mqtt_gpio (INFO): Connected to the MQTT broker with protocol v3.1.1.
mqtt_gpio (INFO): Subscribed to topic: 'office/light/output/lights/set'
mqtt_gpio (INFO): Subscribed to topic: 'office/light/output/lights/set_on_ms'
mqtt_gpio (INFO): Subscribed to topic: 'office/light/output/lights/set_off_ms'
On The RPI3 in SSH the lamp is ON with :
mosquitto_pub -h ip_broker -d -u user -P password -t home/light/output/lights/set_off_ms -m 1
Why in the off topic ?
And when I want integrate a MQTT light on Home assistant it isn’t work.
So if anyone knows the answer and how fix this ?
Thanks for reading.
