I want to control my bed motors. The bed comes with a remote, and when I tried to learn it’s codes via Broadlink rm mini nothing was received - so I suppose it’s not 433hz.
What can it be? 2.4ghz?
With what hardware can I control it?
I have tried to look inside the remote and see, maybe one of you can recognize it…
The remote and the motor unit:
Thanks, but I’m not sure that you read it right, here is a clearer photo.
It think that this is what written there - and it’s not in the db https://fccid.io/2AITPHJC0
That transmitter appears to connect with an SPI bus, using a nodemcu or adruino you might be able to snoop on that, clone the command codes, then transmit them directly using another transmitted yanked from a duplicate remote
