Control blinds with esphome
I’m trying to create a program in ESPHome to tilt the blinds. In the blind I have two relays, open and closed, and a potentiometer for the position. Also a switch to operate the blinds manually.
I want to create an automation in Home Assistant where I can move the blinds to a certain position. For example, blinds to 30%.
So far I have tried the following. In Home Assistant I can only go in one direction and how can I make the blinds move to a certain position?
Who can help me with this?
esphome:
  friendly_name: Jalousie
esp8266:
  board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key:
ota:
  password:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Jalousie Fallback Hotspot"
    password:
captive_portal:
#variabelen
globals:
  - id: richting
    type: bool
    restore_value: true
    initial_value: 'true'
#potmeter
  - platform: adc
    pin: A0
    update_interval: .2s
    filters:
      - multiply: 100
      - filter_out: 100
    accuracy_decimals: 0
    on_value_range:
      - above: 90
        then:
         - switch.turn_off: output_d5
      - below: 10
        then:
         - switch.turn_off: output_d6
switch:
  - platform: gpio
    pin: D5
  - platform: gpio
    pin: D6
    name: "Handbediening richting"
    turn_on_action:
      - globals.set:
          value: 'true'
    turn_off_action:
      - globals.set:
          value: 'false'
#handbediening schakelaar
binary_sensor:
  - platform: gpio
    pin:
      number: D4
      inverted: true
    filters:
      - delayed_on: 25ms
      - delayed_off: 25ms
    name: "hand bediening"
    on_press:
      then:
        if:
          condition:
            - switch.is_on: handb_richting
          then:
            - switch.turn_off: handb_richting
            - if:
                condition:
                  - lambda: return id(potmeter).state < 90;
                then:
                  - switch.turn_on: output_d5
          else:
            - switch.turn_on: handb_richting
            - if:
                condition:
                  - lambda: return id(potmeter).state > 10;
                then:
                  - switch.turn_on: output_d6
    on_release:
cover:
    name: "Jalousie BG zij 1"
    open_action:
    close_action:
    stop_action:
Have little experience with cover, so far have couple ideas.
Add has_position: true to cover config and publish position from adc sensor to cover, like this:
    on_value:
      - lambda: |-
          float pos = x;
          if (x<10) { pos = 0; } else if (x>90) { pos = 100; }
          id(Jalousie_BG_Z1).position = pos/100.0;
          id(Jalousie_BG_Z1).publish_state();
Then on_value_range imho can be removed, as cover wil natively know position & will stop reaching end. But need to check it.
In cover defined what switches to operate to open/close/stop, so IMHO need to issue f.e. cover.close instead of simulating cover operations out of it.
Thank you very much. This is what I was looking for.
The “on_value_range” is for switching off the relays. The if in “on_value” in cover is for enable/disable the buttons in Home Assistant.
Did you get your project working? Would you mind sharing your yaml?
Here is my yaml. I now have 5 working blinds.
#variabelen
globals:
  - id: richting
    type: bool
    restore_value: true
#potmeter
  - platform: adc
    pin: A0
    unit_of_measurement: "%"
    filters:
      - multiply: 100
      - filter_out: 100
    on_value_range:
      - above: 96
        then:
      - below: 10
        then:
    on_value:
      - lambda: |-
          float pos = x;
          id(jalousie).position = pos/100.0;
          id(jalousie).publish_state();
switch:
  - platform: gpio
    pin: D5
  - platform: gpio
    pin: D6
    turn_on_action:
      - globals.set:
          value: 'true'
    turn_off_action:
      - globals.set:
          value: 'false'
    lambda: return id(richting);
binary_sensor:
  - platform: gpio
    pin:
      number: D4
      inverted: true
    filters:
      # Small filter, to debounce the button press.
      - delayed_on: 25ms
      - delayed_off: 25ms
    on_press:
      then:
        if:
          condition:
          then:
            - if:
                condition:
                  - lambda: return id(potmeter).state < 80;
                then:
                  - delay: 10 sec
          else:
            - if:
                condition:
                  - lambda: return id(potmeter).state > 20;
                then:
                  - delay: 10 sec
    on_release:
cover:
  - platform: feedback
    max_duration : 5 sec
    open_action:
    open_duration: 5 sec
    close_action:
    close_duration: 5 sec
    stop_action:
Awesome thank you!
