I have a Kasa 3-way dimmer switch. All the rest of their switches - single pole, single pole dimmer, three way - they all work great. But this 3-way dimmer… Less than rock solid.
In any event, if the brightness is at max level, the lights won’t turn off from the “remote” switch. So, I’d like some kind of automation that fires when the lights are turned on, as well as when the brightness is adjusted, so that the brightness can never be above 85%.
I cannot seem to figure out how to do this. Can anyone help? Even if it involves Node Red (I’d need some pretty specific instructions for that though, since I have no Node Red automations yet)…
Thank you! That ended up not being QUIT the solution, but you pointed me in the right direction. I had to adjust the raw brightness value instead of trying to use the percent.
