Control CCT light with pushbutton - Esphome
Hello, I am using Esphome to control a CCT led strip that I have installed in a desk lamp. I can control it in Home Assistant and in the integration with Homekit, but I would like to control it with a button connected directly to the same Esp8266 since the lamp before connecting it to an ESP8266 could turn it on directly from the button.
I manage to control the on/off of the led strip from a button as long as I use the “monochromatic” platform, but then I lose the option to control the color temperature. As soon as I switch to the “cwww” platform it no longer works. I would like to continue using the “cwww” platform. Is there someone who can help me? I’m not very good with code, and I’m lost. This is the code I’ve been trying but I can’t get it to work.
esphome:
esp8266:
  board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "##################################"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Led-Cct Fallback Hotspot"
    password: "secret wifi_password"
captive_portal:
binary_sensor:
  - platform: gpio
    pin:
      number: D7
      mode: INPUT_PULLUP
      inverted: yes
    on_click:
      then:
        - switch.toggle:
switch:
  - platform: gpio
    pin:
      number: D4
      inverted: yes
    restore_mode: ALWAYS_OFF
    icon: "mdi:fire"
    optimistic: true
    lambda: 'return id(led_relay).state;'
    turn_on_action:
      - light.turn_on:
      - light.turn_off:
      - switch.turn_on:
    turn_off_action:
      - light.turn_off:
      - light.turn_on:
      - switch.turn_off:
light:
  - platform: cwww
    name: "Led Temperature Color"
    cold_white: output_component1
    warm_white: output_component2
    cold_white_color_temperature: 6536 K
    warm_white_color_temperature: 2000 K
    constant_brightness: true
output:
  - platform: esp8266_pwm
    pin: D2
    pin: D1
    inverted: false
I think that is probably because you are turning off the output not the light.
