Control Central Air Thermostat based on temperatures in various rooms
My thermostat sits in the dining room on the first floor, so settings based on temperature are taken from the value there. However, there are many cases where I’d like to set the heat or air conditioning based on values in various rooms.
For example:
  • During the peaks of summer and winter, our sunroom may be 10-15 degrees different than next to the dining room
  • If I’m working in the basement, it can be up to 10 degrees cooler than the dining room
  • At night we want to keep our kids rooms between 68-72 degrees, which does not usually align with the thermostat
I have temperature sensors in all of the rooms but do not use them for anything other than reporting at the moment. Is there any way to create an automation and/or controllable lovelace widget to set the thermostat actions based on another room’s temperature sensor value?
have you read this
I did this
work well
