Control Chihiros aquarium devices from Home Assistant via ESPHome (BLE bridge, no cloud, no app)
I replaced the Chihiros app entirely with an ESP32-S3 running ESPHome. All devices are exposed to Home Assistant as native entities — no cloud, no phone required.
Supported devices
  • CO2 Controller — Working :white_check_mark:
  • Magnetic Stirrer (4-channel) — Working :white_check_mark:
  • Cooling Fan — Working :white_check_mark:
  • Doctor Mate (TDS/EC meter) — Working :white_check_mark:
  • WRGB II light — Working :white_check_mark:
  • Dosing Pump — Working :white_check_mark:
How it works
All Chihiros devices use the Nordic UART Service (NUS) over BLE. Connections are non-persistent by design: the ESP32 connects, sends commands, then disconnects. Most devices store their schedule on an internal RTC, so you only reconnect when something changes.
A shared chihiros_ble.h header handles the full protocol — framing, CRC, sequence numbers, RTC sync, and per-device command sets. The YAML configs use this as a local ESPHome external component.
The protocol was reverse-engineered from Bluetooth HCI btsnoop logs captured with a rooted Android phone.
Frame format:
[header] [0x01] [len] [0x00] [seq] [cmd] [data...] [XOR-CRC]
What you get in Home Assistant
  • CO2: schedule tied to photoperiod with configurable pre-start offset
  • Stirrer: 4 channels on/off, speed sliders, interval timer, per-channel enable
  • Cooling fan: start/max temperature thresholds, silent mode toggle, live water temp + room temp + humidity sensors
  • Doctor Mate: TDS target (Plant/Fish/Shrimp presets or manual), tank volume, live EC sensor
  • WRGB2: auto schedule (RGB + ramp time + photoperiod) or manual brightness sliders per channel
  • Dosing pump: 3 pumps, per-pump weekly schedule (day/time/volume), manual dose button
Hardware
  • ESP32-S3-N16R8
  • Powered by USB or 5V
BLE 5.0 required — Chihiros devices use BLE 5.0 extended advertising, which is invisible to BLE 4.x hardware. A classic ESP32 will not detect them at all. The S3 is also recommended for its extra RAM when running the BLE scanner alongside multiple client connections.
GitHub: GitHub - BartdeJonge/chihiros-esphome · GitHub
Happy to answer questions about the protocol details. If you have a Chihiros device not on the list, I can help figure out the frames with btsnoop logs.
You mention “3 pumps” in the dosing pump section. Does this mean it’s not the Dosing Mate pumps that come in either 2 or 4 pump configurations that have been setup?
The manual dose button would be very helpful for my auto water change setup to dose fertilisers after a water change. I have a 2 head Dosing Mate where you have to set a manual dose amount before dosing.
Cool.
I own a WRGB2 lamp and many spare ESPs.
Is it possible to edit the light schedule on the lamp?
I got the config running on a xiao S3 board :wink:
and will test some more
dude this is so awesome! i was basically searching for that for over a year :smiley:
I did some improvements on your implementation, maybe you (and someone else) may find it useful: GitHub - d1rty-pixel/chihiros-ble-proxy: ESPHome / Chihiros BLE Proxy · GitHub
it still has some quirks, but I'll update this the next days
cheers, and thanks again!
Amazing! Thank you for this. I have managed to connect both my dosing mate 2-head dosing pumps and have them auto-dose after water changes.
