Control chromecast with RESTful interface
I could use some help. I’d like to control Chromecast devices (added to homeassistant) via the homeassistant RESTful interace (eg. change volume, toggle play/pause, start a media stream, etc).
I’ve figured out how to use the RESTful interface from the REST API documentation (https://developers.home-assistant.io/docs/api/rest/), but I don’t see any documentation on controlling media platers, like chrome cast devices. Is there any documentation available?
Thank you!
POST /api/services/<domain>/<service>
The url is the domain and service you want to call, the optional json is the data you want to pass to the service (e.g. entity id etc of the chromecast etc.)
Thank you, very helpful.
Using the GET /api/services command I found the following service commands for media_player domain:
{"domain": "media_player",
"services":
     "clear_playlist": {"description": "Send the media player the command to clear players playlist.", "fields": {"entity_id": {"description": "Name(s) of entities to change source on.", "example": "media_player.living_room_chromecast"}}},
     "media_next_track": {"description": "Send the media player the command for next track.", "fields": {"entity_id": {"description": "Name(s) of entities to send next track command to.", "example": "media_player.living_room_sonos"}}},
	 "media_pause": {"description": "Send the media player the command for pause.", "fields": {"entity_id": {"description": "Name(s) of entities to pause on.", "example": "media_player.living_room_sonos"}}},
	 "media_play": {"description": "Send the media player the command for play.", "fields": {"entity_id": {"description": "Name(s) of entities to play on.", "example": "media_player.living_room_sonos"}}},
	 "media_play_pause": {"description": "Toggle media player play/pause state.", "fields": {"entity_id": {"description": "Name(s) of entities to toggle play/pause state on.", "example": "media_player.living_room_sonos"}}},
	 "media_previous_track": {"description": "Send the media player the command for previous track.", "fields": {"entity_id": {"description": "Name(s) of entities to send previous track command to.", "example": "media_player.living_room_sonos"}}},
	 "media_seek": {"description": "Send the media player the command to seek in current playing media.", "fields": {"entity_id": {"description": "Name(s) of entities to seek media on.", "example": "media_player.living_room_chromecast"}, "seek_position": {"description": "Position to seek to. The format is platform dependent.", "example": 100}}},
	 "media_stop": {"description": "Send the media player the stop command.", "fields": {"entity_id": {"description": "Name(s) of entities to stop on.", "example": "media_player.living_room_sonos"}}},
	 "play_media": {"description": "Send the media player the command for playing media.", "fields": {"entity_id": {"description": "Name(s) of entities to seek media on", "example": "media_player.living_room_chromecast"}, "media_content_id": {"description": "The ID of the content to play. Platform dependent.", "example": "https://home-assistant.io/images/cast/splash.png"}, "media_content_type": {"description": "The type of the content to play. Must be one of image, music, tvshow, video, episode, channel or playlist", "example": "music"}}},
	 "select_sound_mode": {"description": "Send the media player the command to change sound mode.", "fields": {"entity_id": {"description": "Name(s) of entities to change sound mode on.", "example": "media_player.marantz"}, "sound_mode": {"description": "Name of the sound mode to switch to.", "example": "Music"}}},
	 "select_source": {"description": "Send the media player the command to change input source.", "fields": {"entity_id": {"description": "Name(s) of entities to change source on.", "example": "media_player.txnr535_0009b0d81f82"}, "source": {"description": "Name of the source to switch to. Platform dependent.", "example": "video1"}}},
	 "shuffle_set": {"description": "Set shuffling state.", "fields": {"entity_id": {"description": "Name(s) of entities to set.", "example": "media_player.spotify"}, "shuffle": {"description": "True/false for enabling/disabling shuffle.", "example": true}}},
	 "toggle": {"description": "Toggles a media player power state.", "fields": {"entity_id": {"description": "Name(s) of entities to toggle.", "example": "media_player.living_room_chromecast"}}},
	 "turn_off": {"description": "Turn a media player power off.", "fields": {"entity_id": {"description": "Name(s) of entities to turn off.", "example": "media_player.living_room_chromecast"}}},
	 "turn_on": {"description": "Turn a media player power on.", "fields": {"entity_id": {"description": "Name(s) of entities to turn on.", "example": "media_player.living_room_chromecast"}}},
	 "volume_down": {"description": "Turn a media player volume down.", "fields": {"entity_id": {"description": "Name(s) of entities to turn volume down on.", "example": "media_player.living_room_sonos"}}},
	 "volume_mute": {"description": "Mute a media player's volume.", "fields": {"entity_id": {"description": "Name(s) of entities to mute.", "example": "media_player.living_room_sonos"}, "is_volume_muted": {"description": "True/false for mute/unmute.", "example": true}}},
	 "volume_set": {"description": "Set a media player's volume level.", "fields": {"entity_id": {"description": "Name(s) of entities to set volume level on.", "example": "media_player.living_room_sonos"}, "volume_level": {"description": "Volume level to set as float.", "example": 0.6}}},
	 "volume_up": {"description": "Turn a media player volume up.", "fields": {"entity_id": {"description": "Name(s) of entities to turn volume up on.", "example": "media_player.living_room_sonos"}}}}},
You can view and play / test the service calls in the UI from the developer tools menu
