DvdE
(DvdE)
April 16, 2023, 6:59pm
1
The automation below does trigger in the morning but not in the evening. What can be causing this?
alias: Open or Close Blinds
description: “”
platform: template
value_template: |-
{% set below_horizon = is_state(‘sun.sun’, ‘below_horizon’) %} >
{% set after_dawn = now().strftime(’%H:%M’) >= ‘18:00’ %} >
{% set above_horizon = is_state(‘sun.sun’, ‘above_horizon’) %} >
{% set after_sunrise = now().strftime(’%H:%M’) >= ‘07:00’ %} >
{% if below_horizon %}
{{ after_dawn }}
{% elif above_horizon %}
{{ after_sunrise }}
{% endif %}
condition:
condition: or
conditions:
condition: sun
after: sunrise
after_offset: “+00:00”
condition: sun
before: sunset
if:
condition: template
value_template: is_state(‘sun.sun’, ‘above_horizon’)
then:
device_id: e777508491d4b745f06ccea9598f4424
domain: cover
entity_id: cover.screen_all
type: open
else:
domain: cover
type: close
mode: single
Your trigger and conditions are confusing.
Please clarify what your goal for the logic of this automation is.
DvdE
(DvdE)
April 17, 2023, 1:25pm
3
The goal is to open the covers at sunrise but not before 07:00 and to close the covers at sunset but not before 18:00
- platform: time
at: "07:00:00"
- platform: sun
event: sunrise
- platform: time
at: "18:00:00"
- platform: sun
event: sunset
condition:
- condition: template
value_template: >
{% if trigger.id == 'open' %}
{{ today_at('07:00') < now()
and is_state('sun.sun', 'above_horizon')
and is_state('cover.screen_all', 'closed') }}
{% else %}
{{ today_at('18:00') < now()
and is_state('sun.sun', 'below_horizon')
and is_state('cover.screen_all', 'open') }}
{% endif %}
- service: cover.{{ trigger.id }}_cover
EDIT: Added sun position to template and fixed a couple “fancy” quote marks
DvdE
(DvdE)
April 17, 2023, 3:26pm
5
Thank you! Will try this one out tonight
DvdE
(DvdE)
April 17, 2023, 5:23pm
6
Works almost Cover closed at 18:00, but sunset is at 20:39. Covers should close at 20:39. However in winter time sunset is before 18:00. In that case covers should close not earlier than 18:00
I should have included the state of the sun sensor in that part of the template so the action execute on the later of the two triggers. I have added it in the original post above.
DvdE
(DvdE)
April 19, 2023, 5:59pm
8
Works great! thank you for your support.
