Control device with mqtt message, lost in the documentation
Just started with home assistant, because i want to use the roborock integration.
I run home assistant in docker environment. I can’t use the node red addon.
But i want to fire a mqtt message (topic/payload) to home assistant to control the roborock integration. The reason why mqtt, i have this environment running in docker, which controls other things in my home environment
I googled and searched. But i get lost in all the documentation.
And a lot of documentation which i read, i get lost in the names that are used.
Is there a manual for dummies, how to setup mqtt to control devices, by sending topic/payload message?
To have HA respond to a MQTT event, first it has to be subscribed to the broker using the MQTT integration.
Then, you have a couple of options. You could use the MQTT Event: MQTT Event - Home Assistant
Or, you can use the MQTT event trigger in an automation: Automation Trigger - Home Assistant
Thanks for your answer.
The MQTT integration i already added, that was the easy job.
Thanks for your 2 links. I will focus on those two, to not get lost in all the information
is there also a manual for dummy users?
I tried to understand the documentation, but it is to complex for me.
I just don’t get it what to setup in home assistant to get it working
It looks like the option " MQTT trigger" could work.
But in the link are nice examples, but not where in home assistant i need to config this.
I am hoping there is a step by step manual how to setup this.
I finally found a way.
I found it in automations.
For me this was a long way to find it, where it was hidden in home assistant
I found the option when i was looking for solution to get the state of a devices published by mqtt. Found it in this thread Post sensor values to MQTT - #22 by baz123
But looking from the documenation side, i never would looked in the automations tab
Well, automations is one spot, but the docs do say to put the YAML code in your configuration.yaml. Thats why I included both links.
