Is it possible to directly toggle (or turn on or off) a switch in HA front end from ESPHome without using an intermediate step?
If so, how do I do this?
I’m stumped and probably missing the obvious.
You can call HA services using the API see: Native API Component — ESPHome
I think this is what you are asking for, you will need a trigger for it.
Thank you.
So, it would be something like:
- homeassistant.service:
service: switch.turn_on
entity_id: switch.myswitch
Is that how it should work?
This works!
Apart from an error in my config. Here’s the correct version:
Yes, the service calls are looking for data, or data_template, glad it worked.
