Control Hello Fairy BLE string lights with esphome
Hello Fairy BLE string lights in ESPHome
Fair warning: I developed these controls running on an ESP32 with ESPHome, not a Home Assistant custom integration using the ESPs as simple Bluetooth proxies. In retrospect, that is a much better path. A year later, I now have rewritten this as a Hello Fairy Integration. So this might be an interesting case study, but use that project for your Hello Fairy lights instead.
Background
I bought some cheap “Hello Fairy” Bluetooth string lights from Amazon for the holidays. They come with an IR remote and you can download a Bluetooth app for your phone.
Everything’s better with Home Assistant, so challenge accepted.
How-To
This is a bit of a process log that might help others to reverse-engineer their own simple BLE devices for Home Assistant.
I don’t have a Bluetooth sniffer, so the first problem was figuring out the relevant Bluetooth uuids. There’s a nice utility called nRF Connect you can get on your phone from the App Store that will let you see Bluetooth advertisements; this was sufficient to find the service UUID, a notification UUID, and the command UUID.
You can also find your BLE MAC address from there, or from the esp32_ble_tracker in esphome.
With the MAC you can set up a ble_client sensor that acts on specific advertisements. In the Hello Fairy case, we get a nice message from the notify UUID whenever the state of the lights is changed by the IR remote control.
Decoding
After pressing many buttons we start to notice some patterns:
#     b/w  aa01 08 000000 01 02 63 0064 7d
#     r/g  aa01 08 000000 01 02 12 0064 2c
#     w    aa01 08 000000 01 02 15 0064 2f
#     red  aa01 0b 000000 01 01 0000 03e8 03e8 8e
#     off  aa01 0b 000000 00 01 0000 03e8 03e8 8d
#     gn   aa01 0b 000000 01 01 0078 03e8 03e8 06
#     b    aa01 0b 000000 01 01 00f0 03e8 03e8 7e
#     y    aa01 0b 000000 01 01 003c 03e8 03e8 ca
The last byte changes for every command - a reasonable hint that it might be a checksum. The on/off state was clearly tied to byte 7. Byte 8 seems to indicate two different command types, 01 for pure colors and 02 for preset patterns. The last two bytes before the checksum seem to remain constant for a given brightness setting, so let’s assume that’s what it means.
For the presets, byte 9 must reflect the preset number.
For the colors, we have 4 remaining unknown bytes, and mostly the second set of 2 remain constant. The first set of 2 always gives a value between 0-359. So it’s not much of a leap to assume HSV with hue 0-3590. Saturation and brightness values range 0-1000, with brightness value changing by 100 for each up/down brightness button press on the remote (which has a range of 10 steps), so let’s assume the 0-1000 means 0-100.0%.
Taking a small leap of faith that the last byte is indeed a checksum, we notice there are 8 data bytes following the ‘08’ commands and 11 bytes following ‘0b’, so byte 3 must be data length. And a simple checksum of those data bytes does indeed match the final checksum value, so now we’ve got the whole thing.
I couldn’t find a HSV light component in ESPHome, so I have to do some math mapping back and forth to RGB, and then I can set my light entity in Home Assistant to match the last IR command state. (hsv2rgb script in the code below). Yay!
Sending commands
Ok, I can now set Home Assistant entity state to match what the IR remote has sent, but how do I send new Bluetooth commands from Home Assistant? Googling around, I found some previous attempts at these lights that revealed exactly three commands: on, off, and something unknown.
# on  aa02 01 01 ae
# off aa02 01 00 ad
# bright? color? aa030701001403e8038cbb
Given my previous discovery, byte 3 must mean data length and the last byte again looks like a checksum. ‘aa02’ must mean power. Now adding some spaces to the unknown command makes it clearer:
aa03 07 01 0014 03e8 038c bb
Last 3 sets of byte pairs look like our HSV, and byte 4 must be the color/preset type from before. So now we should be able to reconstruct any command.
There’s only one writable Bluetooth attribute advertised, so that’s the one to try to set. (We can actually use the nRF Connect app to write here to test out our theory before coding up anything in esphome.) But in the end: success!
The Code
There was significant pain trying to deal with HSV<->RGB conversion, mainly because ESPHome seems to just use RGB to indicate hue and tracks brightness in a separate attribute. Anyhow, I kind of glued this together in code in probably not the best manner.
Another tricky bit was to try to get the light entity to both display the color set via the remote, and also to be able to set the lights itself. It kind of goes like: set color with remote updates the light entity in esphome. The light entity realizes it was changed, so it then tries to set the color. So I have to temporarily disable the light entity change effects if we were just updated from the remote.
Third tricky bit was that the light entity actually doesn’t just switch to a new color, it tries to transition over a period of time. This means it sends commands repeatedly, and it was not obvious how to stop that. I ended up using an acknowledge message coming from the lights on the BLE notify attribute to ignore the recurring sends until the lights were ready for the next step in the transition, and then make sure that the final (target color) command was sent. (Edit: setting transition time to 0 makes this easier.)
So the code looks significantly more complicated than I had wished or expected. In retrospect, it would probably have been a better idea to do this with a custom integration in Home Assistant directly and used the ESPHome Bluetooth Proxy to simply pass the messages. This would also let it work across any bluetooth proxy in your home, not just a specific esp. Oh well, next time…
(Change fairy_mac below to yours…)
packages:
  esphome.bluetooth-proxy: github://esphome/firmware/bluetooth-proxy/esp32-generic.yaml@main
  esp32: !include .common-esp32.yaml
  common: !include .common.yaml
substitutions:
  friendly_name: Airy
  svcuuid: 49535343-fe7d-4ae5-8fa9-9fafd205e455
  cmduuid: 49535343-8841-43f4-a8d4-ecbe34729bb3
  ntfuuid: 49535343-1E4D-4BD9-BA61-23C647249616
  fairy_mac: 11:11:00:32:40:FD
globals:
  - id: fairy_name
    type: std::string
    restore_value: no
  - id: fhsv
    type: int[3]
    restore_value: yes
  - id: acked
    type: bool
    restore_value: no
    initial_value: 'true'
  - id: deferred_send
    type: bool
    restore_value: no
    initial_value: 'false'
  - id: notify_only
    type: bool
    restore_value: no
  - id: delay_counter
    type: int
    restore_value: no
    initial_value: '0'
  - id: delay_old
    type: int
    restore_value: no
    initial_value: '0'
esp32_ble_tracker:
  on_ble_advertise:
    - mac_address:
      then:
        - lambda: |-
            if (x.get_name().find("Hello Fairy-") != 0)
              return;
            if (id(fairy_name) == x.get_name())
              return;
            if (x.address_str() == "${fairy_mac}")
              id(fairy_name) = x.get_name();
            ESP_LOGD("ble_adv", "New BLE device");
            ESP_LOGD("ble_adv", "  address: %s", x.address_str().c_str());
            ESP_LOGD("ble_adv", "  name: %s", x.get_name().c_str());
            for (auto data : x.get_manufacturer_datas()) {
                ESP_LOGD("ble_adv", "  manufacturer: %s", data.uuid.to_string().c_str());
ble_client:
  - mac_address: ${fairy_mac}
    auto_connect: true
    on_connect:
      then:
        - lambda: |-
            ESP_LOGD("ble_client_lambda", "Connected to BLE device %s", id(fairy_name).c_str());
            id(bleconn).publish_state(true);
    on_disconnect:
      then:
        - lambda: |-
            ESP_LOGD("ble_client_lambda", "Disconnected from BLE device %s", id(fairy_name).c_str());
            id(bleconn).publish_state(false);
  - platform: ble_client
    type: characteristic
    ble_client_id: fairy_cli
    service_uuid: ${svcuuid}
    characteristic_uuid: ${cmduuid}
    internal: true
    update_interval: 60s
    lambda: |-
      std::string resp = "";
      char buffer[3];
      for (int i = 0; i < x.size(); i++) {
        sprintf(buffer, "%02x", x[i]);
        resp += buffer;
      // Reading cmd always gets this
      if (resp != "68656c6c6f00") {
        ESP_LOGD("cmd", "read %d bytes %s", x.size(), resp.c_str());
      return 0.0;
    characteristic_uuid: ${ntfuuid}
    notify: true
    internal: true
    # polling this uuid doesnt work
    update_interval: 24h
    lambda: |-
      //ESP_LOGD("ntfy", "status notify: %d", x.size());
      char buffer[3];
        resp += buffer;
      if (x.size() == 4) { // ACK aa0200ac, aa0300ad
        ESP_LOGD("ntfy", "command %d ACK", x[1]);
        id(acked) = true;
        return 0.0;
      if (x.size() < 12) {
        ESP_LOGD("ntfy", "unknown response %s", resp.c_str());
        return 1.0;
      // Interesting part after byte 6
      id(fe_status).publish_state(resp.substr(12));
      // byte 6 is power state
      id(fe_power).publish_state(x[6]);
      if (x[6] == 0) {
        // Make light entity match reported state
        id(fe_rgb).turn_off().perform();
        return (float)x.size();
      if (x[7] == 1) { // hsv
        //c8-9  	hsv color	    xxxx	H 0-359 degrees
        //c10-11	hsv sat 	    xxxx	0?-1000
        //c12-13  hsv bright    xxxx	100-1000 by 100's
        id(fhsv)[0] = x[8] * 256 + x[9];
        id(fhsv)[1] = (x[10] * 256 + x[11]) / 10;
        id(fhsv)[2] = (x[12] * 256 + x[13]) / 10;
        ESP_LOGD("ntfy", "mode=color: HSV(%d,%d,%d)", id(fhsv)[0], id(fhsv)[1], id(fhsv)[2]);
        // Change the light entity to match reported fairy state;
        // don't send new settings to fairy
        id(notify_only) = true;
        id(hsv2rgb)->execute();
      } else if (x[7] == 2) { // Preset
        int preset = x[8];
        int bright = (x[9] * 256 + x[10]) / 10;
        ESP_LOGD("ntfy", "mode=preset: p=%d V=%d", preset, bright);
        auto call = id(fe_preset).make_call();
        call.set_value(preset);
        call.perform();
      } else {
        ESP_LOGD("ntfy", "mode=%d unknown", x[7]);
binary_sensor:
    device_class: connectivity
    entity_category: diagnostic
text_sensor:
    icon: mdi:remote-tv
    on_value:
      then:
        - lambda: |-
            ESP_LOGD("text", "New notify %s", x.c_str());
script:
  - id: print_state
    mode: single
    parameters:
      tag: string
    then:
      - lambda: |-
          ESP_LOGD("light", "tag=%s s=%f, b=%f rgb(%f,%f,%f)", tag.c_str(),
              id(fe_rgb).current_values.get_state(),
              id(fe_rgb).current_values.get_brightness(),
              id(fe_rgb).current_values.get_red(),
              id(fe_rgb).current_values.get_green(),
              id(fe_rgb).current_values.get_blue());
          return;
  - id: hsv2rgb
    mode: single
    then:
      - lambda: |-
          ESP_LOGD("h2r", "HSV(%d,%d,%d) ->", id(fhsv)[0], id(fhsv)[1], id(fhsv)[2]);
          ESPHSVColor hsv(id(fhsv)[0]*255/360, id(fhsv)[1]*255/100, id(fhsv)[2]*255/100);
          Color rgb = hsv.to_rgb();
          // Transition the light entity in the frontend;
          ESP_LOGD("h2r", "->RGB(%f,%f,%f)", rgb.r/255.0,rgb.g/255.0,rgb.b/255.0);
          id(print_state)->execute("h2r_pre");
          auto call = id(fe_rgb).turn_on();
          call.set_transition_length(0); // in ms
          call.set_color_mode(ColorMode::RGB);
          call.set_brightness(id(fhsv)[2]/100.0);
          call.set_rgb(rgb.r/255.0,rgb.g/255.0,rgb.b/255.0);
          call.perform();
          id(print_state)->execute("h2r_post");
          return;
  - id: rgb2hsv
    mode: single
    parameters:
      tag: string
    then:
      - lambda: |-
          float r = id(fe_rgb).current_values.get_red();
          float g = id(fe_rgb).current_values.get_green();
          float b = id(fe_rgb).current_values.get_blue();
          ESP_LOGD("r2h", "%s RGB(%f,%f,%f) ->", tag.c_str(), r, g, b);
          float v = max(r, max(g, b));
          float n = v - min(r, min(g, b));
          float h;
          if (n == 0) {
            h = 0;
          } else if (v == r) {
            h = (g - b) / n;
          } else if (v == g) {
            h = 2 + (b - r) / n;
          } else {
            h = 4 + (r - g) / n;
          if (h < 0) {
            h += 6;
          id(fhsv)[0] = (int)(60 * h);
          id(fhsv)[1] = (int)(v ? (n / v) * 100 : 0);
          //id(fhsv)[2] = (int)(v * 100);
          // light entity has a separate brightness channel
          id(fhsv)[2] = (int)(id(fe_rgb).current_values.get_brightness() * 100);
          ESP_LOGD("r2h", "-> HSV(%d,%d,%d)", id(fhsv)[0], id(fhsv)[1], id(fhsv)[2]);
          return;
  - id: sendhsv
    mode: single
    then:
      - if:
          # don't send commands if we're just being notified (i.e. ir remote)
          # or if we're still waiting for a response.
          condition:
            lambda: |-
              //ESP_LOGD("send", "n/o=%d, ack=%d", id(notify_only), id(acked));
              if (!id(notify_only) && !id(acked)) {
                // We're not notifying but can't send yet because we're still waiting for the last ack
                ESP_LOGD("send", "skipping send (previous unacked)");
                id(deferred_send) = true;
              return (!id(notify_only) && id(acked));
          then:
            - ble_client.ble_write:
                # lambda returning an std::vector<uint8_t>
                value: !lambda |-
                    // send color on from hsv as (0-360,0-1000,0-1000)
                    ESP_LOGD("send", "HSV(%d,%d,%d)", id(fhsv)[0], id(fhsv)[1], id(fhsv)[2]);
                    std::vector<uint8_t> cmd = {0xaa,0x03,0x07,0x01,0xff,0xff,0xff,0xff,0xff,0xff,0xff};
                    cmd[4] = id(fhsv)[0] / 256;
                    cmd[5] = id(fhsv)[0] % 256;
                    cmd[6] = (id(fhsv)[1]*10) / 256;
                    cmd[7] = (id(fhsv)[1]*10) % 256;
                    cmd[8] = (id(fhsv)[2]*10) / 256;
                    cmd[9] = (id(fhsv)[2]*10) % 256;
                    int csum = 0;
                    for (int i = 0; i < cmd.size(); i++) {
                      csum += cmd[i];
                    cmd[10] = csum % 256;
                    std::string msg = "";
                    char buffer[4];
                      sprintf(buffer, "%02x ", cmd[i]);
                      msg += buffer;
                    id(acked) = false;
                    id(deferred_send) = false;
                    ESP_LOGD("send", "set hsv %s", msg.c_str());
                    return cmd;
  - id: sendpatt
    mode: single
    parameters:
      pattern: int
    then:
      - if:
          condition:
            lambda: 'return (!id(notify_only));'
          then:
                value: !lambda |-
                  ESP_LOGD("send", "patt (%d)", pattern);
                  std::vector<uint8_t> cmd = {0xaa,0x03,0x04,0x02,0xff,0xff,0xff,0xff};
                  cmd[4] = pattern % 256;
                  cmd[5] = (id(fhsv)[2]*10) / 256;
                  cmd[6] = (id(fhsv)[2]*10) % 256;
                  int csum = 0;
                    csum += cmd[i];
                  cmd[7] = csum % 256;
                  { // print
                    char buffer[4];
                      msg += buffer;
                    ESP_LOGD("send", "set patt %s", msg.c_str());
                  id(acked) = false;
                  return cmd;
          else:
            - globals.set:
                value: 'false'
  # countdown to find the end of transition changes
  - id: countdown
    mode: single
    then:
      - lambda: |-
          id(delay_counter) = 1;
          id(delay_old) = 1;
      - delay: 200ms
      - while:
          condition:
            lambda: |-
              if (id(delay_counter) > id(delay_old)) {
                id(delay_old) = id(delay_counter);
                return true;
              } else {
                return false;
          then:
            - delay: 200ms
      - lambda: |-
          id(delay_counter) = 0;
          id(delay_old) = 0;
          return;
      #- script.execute:
      #    id: sendhsv
      - delay: 100ms
      - globals.set:
          value: 'false'
      - globals.set:
          value: 'true'
# Sends on/off commands to Fairy
switch:
    device_class: switch
    restore_mode: RESTORE_DEFAULT_OFF
    optimistic: true
    internal: true
    turn_on_action:
          value: [0xaa,0x02,0x01,0x01,0xae]
    turn_off_action:
          value: [0xaa,0x02,0x01,0x00,0xad]
number:
    icon: mdi:car-shift-pattern
    min_value: 1
    max_value: 58
    step: 1
    optimistic: True
    restore_value: True
    set_action:
      - if:
          condition:
            switch.is_off: fe_power
          then:
            light.turn_on: fe_rgb
      - script.execute:
          pattern: !lambda 'return x;'
# This exposes a rgb light entity on the HA side
light:
  - platform: rgb
    icon: mdi:string-lights
    red: red
    green: green
    blue: blue
    default_transition_length: 0ms
    on_state:
      - logger.log: "Light State Change"
      - script.execute:
          tag: "light state"
      - script.execute:
    on_turn_on:
      - logger.log: "Light On"
      - script.execute:
          tag: "light pre-on"
      - switch.turn_on:
      - script.execute:
          tag: "light post-on"
    on_turn_off:
      - logger.log: "Light Off"
      - switch.turn_off:
    effects:
      - random:
          transition_length: 0s
          update_interval: 5s
      - lambda:
          name: "Blue & White"
          lambda: |-
            id(fe_preset).make_call().set_value(41).perform();
      - lambda:
          name: "Orange Fireworks"
          lambda: |-
            id(fe_preset).make_call().set_value(58).perform();
# The values here are set from the HA-side color picker,
# starting from the previous settings,
# driven in a sequence over the transition time.
output:
    type: float
    write_action:
      - lambda: |-
          //ESP_LOGD("outp", "adj red   %f", state);
          id(delay_counter)+=1;
          return;
    type: float
    write_action:
      - lambda: |-
          //ESP_LOGD("outp", "adj green %f", state);
          return;
    type: float
    write_action:
      - lambda: |-
          //ESP_LOGD("outp", "%d adj blue  %f", id(delay_counter), state);
          return;
      - script.execute:
          tag: 'blue'
      - if:
          condition:
          then:
            - script.execute:
# Reverse-engineering notes follow...
# "transparent uart" tx/rx uuids
# tx: 49535343-1E4D-4BD9-BA61-23C647249616 -- notify
# broadcasts status update when notify is on, some samples"
#     red  aa01 0b00 0000 0101 0000 03e8 03e8 8e
#     off  aa01 0b00 0000 0001 0000 03e8 03e8 8d
#     gn   aa01 0b00 0000 0101 0078 03e8 03e8 06
#     off                 00                   last bit=previous-1
#     b    aa01 0b00 0000 0101 00f0 03e8 03e8 7e
#     y    aa01 0b00 0000 0101 003c 03e8 03e8 ca
# decoding notify status:
#Byte   Meaning       Value
#0-1    prefix        aa01
#2      cmd len       08/0b
#3-5    ?             000000
#6      on/off        01/00
#7      color/preset  01/02
#c8-9   hsv color     xxxx  0-359 deg
#c10-11 hsv sat       xxxx  0?-1000  (100.0%)
#c12-13 hsv bright    xxxx  100-900 by 100's (100.0%)
#c14    csum          xx  simple sum checksum
#p8     preset#       xx  01-ff?
#p9-10  hsv bright
#p11    csum
# rx: 49535343-8841-43f4-a8d4-ecbe34729bb3 -- w,r, w w/o resp
# on  aa020101ae
# off aa020100ad
# response ACK on tx in both cases: aa0200ac
# decoding cmd
#Byte   Meaning       Value
#0      prefix        aa
#1      cmd           02=power, 03=color/preset
#2      len           01/07
#p3     off/on        00/01
#p4     csum          simple sum checksum
#c3     color/preset  01/02
#c4-5   hsv H 0-359
#c6-7   hsv S 0-1000
#c8-9   hsv L 100-900 by 100's
#c10    csum
#dim gn should be: aa 03 07 01 0078 03e8 03e8 03
# patt pp should be: aa03 ln 02 pp 03e8 cs
This is awesome. If i wanted to control various strings it would be possible to add additional ble clients and corresponding substitutions ofc correct?
I’ve never made a custom component for HA but I’m currently doing some preliminary research. Might take a run at it if I can wrap my head around it
GitHub - vrutkovs/ha-hello-fairy-integration might be a good start, but I can’t figure out yet how to convert RBG + Brightness into HSV
My code above has a rgb2hsv script
Yes - this code assumes one string with the ble mac address hard-coded. The esp32_ble_tracker component will print any advertised macs for the Hello Fairly lights to the debug log, but the ble_client component yaml apparently needs a constant for mac_address. This wouldn’t be an issue if you make a custom component in python.
I’m playing around with that integration, and I’ve gotten it to discover my strings using an ESP32 BLE proxy, but turning on and off does not actually work, and it doesn’t read the correct on / off state.
What have you changed in your fork vs Alwinator?
Did you look into setting individual pixels? I think I’ll play with PacketLogger and see if I can make progress on that one.
AAD1 0300 0096 BB
AAD1 0300 000C BB
AAD1 0300 003C BB
When I toggle the top right pixel it seems like the 3rd set is the color. :slight_smile:
This is very cool stuff. I just picked up a couple hello fairy lights off of Amazon. I am fairly new to Home Assistant but this seems like a good project to learn how custom integration works.
