I am building a script to control som philips hue lights.
I need to change the schene.
I have a input select:
input_select:
spisebord_room_preset:
options:
- Relax
- Read
- Concentrate
- Energize
My question is how do i use these options to control the lights:
when hardcoding it works:
- alias: Set spisebord_room_preset
platform: state
entity_id: input_select.spisebord_room_preset
service: light.hue_activate_scene
group_name: 'Spisebord'
scene_name: 'Energize'
but not when scripting:
platform: state
scene_name: '{{ states.input_select.spisebord_room_preset.state }}'
I have tryed all sorts of combinations with no luck:
scene_name: {{ states.input_select.spisebord_room_preset.state }}
scene_name: "{{ states.input_select.spisebord_room_preset.state }}"
scene_name: "{{ states.input_select.spisebord_room_preset}}"
Not sure, but i think you should use data_template in your action.
wmn79
April 3, 2017, 9:12am
3
Maybe it works with something like this:
Create an automation like this:
platform: state
service: script.turn_on
entity_id: script.input_select_spisebord_script
And this in your scripts.yaml or under scripts section in your configuration.yaml:
- input_select_spisebord_script:
alias: "Set spisebord_room_preset"
sequence:
data_template:
scene_name: >
{% if is_state("input_select.spisebord_room_preset", "Relax") %}
'Relax'
{% elif is_state("input_select.spisebord_room_preset", "Read") %}
'Read'
{% elif is_state("input_select.spisebord_room_preset", "Concentrate") %}
'Concentrate'
{% elif is_state("input_select.spisebord_room_preset", "Energize") %}
'Energize'
{% endif %}
Good luck!
Hi all
Thank you for your replies, it lead me very much in the right way.
Below is the working solution
platform: state
data_template:
scene_name: >
Relax
Read
Concentrate
Energize
{% endif %}
Maybe it could be a little shorter with:
data_template:
scene_name: '{{ trigger.to_state.state }}'
Just an attempt.
nelbs
July 10, 2017, 9:40pm
7
This is exactly what I needed. Thanks!
I also want to turn off the lights with the same input panel. Can anyone tell me how to achieve this? I tried running a script within the if function in automation but that didnt do the job…
