For the power monitoring, I use node red. But you can do it just as well in home assistant directly. I think this works fine nowadays. Node red is rather complicated anyway.
Normally, when the machine is off: power usage < 5W. i.e. 0.3W.
When the machine is turned on it spikes >5W. Result> trigger flip boolean on.
During the cycle the power varies between 3-2500W, but duration <5 W is shorter than 3 minutes.
Ultimately, when machine is done with the cycle, it drops below 5W for a longer period (than 3mins) > trigger flip boolean off
When the boolean is flipped from on>off, the script notify action is triggered only to persons who are home.
Dont want my wife to find out I am doing the laundry while she is away, huh…
Why use the boolean in the first place one would ask. Well, I noticed if I was messing and rebooting HA, my wife gets e-mails constantly. This lower threshold of 5W prevents this which in turn increases the WAF a lot.
The notify method I use with mail is like this:
script:
notify_nick:
sequence:
- service: notify.nick
title: Wasmachine is klaar
message: Dit is een automatisch gegenereerde e-mail. U hoeft hier niet op te
reageren
notify_bianca:
sequence:
- service: notify.bianca
reageren
notify:
- name: nick
platform: smtp
server: smtp.gmail.com
port: 587
timeout: 15
sender: [email protected]
encryption: starttls
username: [email protected]
password: password_of_emailadress
recipient:
- [email protected]
sender_name: Home-Bot
maybe this helps someone
