I tried certain things but nothing worked, it doesn’t matter, I’ll see about it another time, the whole thing is already functional.
THANKS
hello blastmun,
I would like to do the same, but the connection between the roller and the dongle is not working.
Did it work for you right from the start?
which system did you flash? under MQTT I see the dongle and information, but the connection does not work
thanks in advance
Andreas
has someone of you also the problem, that your dongle is working for around 1 day and than quit, i.e. pressing a button (in HA or the JaroliftMQTT web interface) has no effect at all? Unless you restart the dongle … any hint would be highly appreciated!
Thanks!
