Situation: I am living in a flat (not my own) where a gas heater is given and cannot be changed. Gas heater is a JUNKERS (Bosch Group) ZWN 16-6 KE23 and the temperature control is a JUNKERS FR120.
Problem: Currently, I have to control the temperature for each room manually in two steps: (1) Turning up the thermostat in the room and (2) activating the central heating on the FR120. That’s laborious!
Goal: I would like to control each room automatically using Home Assistant at the best.
For the control of each single room I could easily install smart thermostats and connect them with Home Assistant. But how to control the central heating (currently controlled by JUNKERS FR120)?
According to my research, the gas heater has only a 1-2-4 analog interface. Therefore I cannot easily install smart solutions I guess, since they require a data bus. Am i right? I thought about a solution using ESP32 microcontroller. But I am also not the electronics expert.
Does anyone have experience how to solve this?
Cheers, red
