I have connected a button to a NodeMCU ESP8266 and would like to use it to always switch a light (light.canvas_48e9) on/off.
I have already found codes online in the documentation, but they somehow only refer to the lights that are directly connected to the ESP.
How can I also control lights from HomeAssistant?
Many thanks in advance for your answer!
I knew I could work it out. I have put this together for you, should work. Also you’ll need to allow your ESPhome device to call home assistant services, this link will help.
Also, have a link to the homeassistant.service info
binary_sensor:
- platform: gpio
pin:
number: GPIO05 # change to your GPIO
mode: INPUT_PULLUP # change if needed
inverted: True # or false
name: "Button1" # change to your prefered name
internal: false # change to true if you don't want it showing in HA
filters:
- delayed_on: 10ms
on_press:
then:
- homeassistant.service:
service: homeassistant.toggle
entity_id: light.uplight # change to your light
Thank you very much!
It has finally worked!
![:partying_face: :partying_face:](https://community.home-assistant.io/images/emoji/twitter/partying_face.png?v=12)
