First of all Merry Christmas to everyone who celebrates it!
These forums have helped me a numerous times, but I can’t seem to find a solution for my current problem. I’m starting to think that I’m overthinking something, so just tell me if this is the case.
I have a LED strip connected to an arduino nano, which has mysensors (fastled library) sketch flashed. The arduino is connected to a Pi with a USB cable. Pi is running HA in a python venv. This works fine.
I also have mqttstatestream set up so I can control all my HAs running a separate Pis (one per each room)
mqttstatestream in general also works fine.
I can turn the LED strip on/off, can set the color. The issue is only with setting the brightness of the LED strip from the master HA.
Now the code:
Light config on the master HA:
- platform: mqtt
command_topic: "beosztottak/szulotv/mqttstates/light/tklampa_0_15/set_status"
state_topic: "beosztottak/szulotv/mqttstates/light/tklampa_0_15/V_STATUS"
state_value_template: "{{ value }}"
brightness_command_topic: "beosztottak/szulotv/mqttstates/light/tklampa_0_15/set_percent"
brightness_state_topic: "beosztottak/szulotv/mqttstates/light/tklampa_0_15/V_PERCENTAGE"
brightness_value_template: "{{ ((value | float / 100) * 255) | int }}"
rgb_command_topic: "beosztottak/szulotv/mqttstates/light/tklampa_0_15/set_rgb"
rgb_state_topic: "beosztottak/szulotv/mqttstates/light/tklampa_0_15/V_RGB"
rgb_value_template: "{{ value }}"
payload_on: "ON"
payload_off: "OFF"
optimistic: true
qos: 2
Automations on the slave HA:
- id: '1619194286185'
alias: TK_lampa_fel
description: ''
- platform: mqtt
topic: beosztottak/szulotv/mqttstates/light/tklampa_0_15/set_status
payload: 'ON'
condition: []
- service: homeassistant.turn_on
data: {}
entity_id: light.tklampa_0_15
mode: single
- id: '1619201591539'
alias: TK_lampa_BRGHT
description: ''
- platform: mqtt
topic: beosztottak/szulotv/mqttstates/light/tklampa_0_15/set_percent
condition: []
data: {}
- service: light.turn_on
brightness: '{{ states.sensor.sen_tk_lampa_brght_korr.state }}'
mode: single
- id: '1619202719976'
alias: TK_lampa_color
description: ''
- platform: mqtt
topic: beosztottak/szulotv/mqttstates/light/tklampa_0_15/set_rgb
condition: []
rgb_color: '{{ states.sensor.tk_lampa_set_rgb.state }}'
mode: single
- id: '1619203224641'
alias: TK_lampa_LE
description: ''
- platform: mqtt
payload: 'OFF'
condition: []
- service: homeassistant.turn_off
data: {}
mode: single
and the config for the MQTT sensors set up on the slave:
- platform: mqtt
state_topic: "beosztottak/szulotv/mqttstates/light/tklampa_0_15/set_percent"
#value_template: "{{ ((value | float / 255) * 100) | int }}"
qos: 0
- platform: mqtt
state_topic: "beosztottak/szulotv/mqttstates/light/tklampa_0_15/set_rgb"
qos: 0
- platform: mqtt
state_topic: "beosztottak/szulotv/mqttstates/light/tklampa_0_15/set_status"
qos: 0
sensors:
sen_tk_lampa_brght_korr:
value_template: '{{ ((states("sensor.tk_lampa_set_percent") | float / 255) * 100) | round(0) }}'
I know that the other automations are not needed for the issue, I just pasted them to show that I’m trying to do something similar to them.
I think I understand the issue: HA is sending a value between 0-255 and the V_PERCENTAGE in mysensors is a 0-100 value.
I have found some posts regarding similar issues, that’s where I’ve got the formula form for sen_tk_lampa_brght_korr, but none of them seems to help me.
What I know until now.
- On the master you need to have separate MQTT topics for command and state
- These separate topics need to use the same value range (eg.:0-255), otherwise the brightness slider “jumps” around when changing it.
- Any math in the “brightness” field of the automation on the slave does not work. That’s why I’ve created sen_tk_lampa_brght_korr sensor
- I’ve also tried to put an attribute to the “brightness” field of the automation on the slave, like “states.light.tklampa_0_15.attributes.brightness” without luck.
The only thing I don’t understand is why doesn’t the value change in sen_tk_lampa_brght_korr change the brightness of the LEDs.
I’m not sure if any logs are needed in this case, because in general things work, so it’s only my way of thinking that needs to be adjusted…
Thanks for the help!
