Control lights based on motion and brightness
This is an extension of the included motion sensor blueprint from Home Assistant. I added another sensor for brightness to only turn on lights if is actually dark. This level can be controlled via another input. If you are looking for more details I described it in my blog post.
blueprint:
  name: Motion and brightness activated Light
  description: Turn on a light when motion is detected and it is dark enough (or night).
  domain: automation
  source_url: https://github.com/OliverHi/blueprints/blob/42a969d6a793c818bfc5cd1ca932b4fa08767ae7/motion_brightness_light.yaml
  input:
    motion_entity:
      selector:
        entity:
          domain: binary_sensor
          device_class: motion
    brightness_entity:
      selector:
        entity:
          device_class: illuminance
    light_target:
      name: Light(s) to control
      selector:
          entity:
            domain: light
    brightness_trigger:
      name: Maximum brightness
      description: Brightness trigger level. If it gets any brighter the lights will not be turned on.
      default: 20
      selector:
        number:
          min: 0
          max: 1000
          unit_of_measurement: lx
    no_motion_wait:
      description: Time to leave the light on after last motion is detected.
      default: 120
      selector:
        number:
          min: 0
          max: 3600
          unit_of_measurement: seconds
# If motion is detected within the delay,
# we restart the script.
mode: restart
max_exceeded: silent
  platform: state
  entity_id: !input motion_entity
  to: "on"
condition:
  - condition: or
    conditions:
      - condition: sun
        before: sunrise
        after: sunset
      - condition: numeric_state
        entity_id: !input brightness_entity
        below: !input brightness_trigger
  - service: light.turn_on
    target: !input light_target
  - wait_for_trigger:
      platform: state
      to: "off"
  - delay: !input no_motion_wait
  - service: light.turn_off
I am using this with Aqara motion sensors which include a brightness (lux) sensor. This blueprint also includes a condition to turn the lights on during the night (after sunset, before sunrise) regardless of the brightness but you can simply remove that if you want to. The sensors used are connected via ZHA but it should work with any other sensor too.
LastSamurai, thanks for the great blueprint. I just use it seamless.
Unfortunately there is a small bug in this automation. If the lights are turned on the brightness in the room will (obviously) increase. This will cause the automation to sometimes turn off the lights again.
To fix this I changed the automation to keep the lights on as long as there is motion. This needs the target selector in the condition though which is not supported.
Fortunately I found a workaround (at least if you only use entities) and added it to my Github as version 2. An in-depth explanation can also be found on my blog.
Here is the updated code:
blueprint:
  name: Motion and brightness activated Light V2
  description: Turn on a light when motion is detected and it is dark enough or night.
  domain: automation
  source_url: https://github.com/OliverHi/blueprints/blob/f010d88630fa3e0d68074905b1258e8580f3b2f6/motion_brightness_light.yaml
  input:
    motion_entity:
      selector:
        entity:
    brightness_entity:
      selector:
        entity:
    light_target:
      selector:
          entity:
            domain: light
    brightness_trigger:
      default: 20
      selector:
        number:
          min: 0
          max: 1000
    no_motion_wait:
      default: 120
      selector:
        number:
          min: 0
          max: 3600
mode: restart
# making the input variable usable in the condition
variables:
  lights: !input "light_target"
  platform: state
  to: "on"
condition:
  - condition: or
    conditions:
      - "{{ expand(lights.entity_id) | selectattr('state', '==', 'on') | list | count > 0 }}" # some lights in the group are on
  - wait_for_trigger:
      platform: state
      to: "off"
