Unfortunately there is a small bug in this automation. If the lights are turned on the brightness in the room will (obviously) increase. This will cause the automation to sometimes turn off the lights again.
To fix this I changed the automation to keep the lights on as long as there is motion. This needs the target selector in the condition though which is not supported.
Fortunately I found a workaround (at least if you only use entities) and added it to my Github as version 2. An in-depth explanation can also be found on my blog.
Here is the updated code:
blueprint:
name: Motion and brightness activated Light V2
description: Turn on a light when motion is detected and it is dark enough or night.
domain: automation
source_url: https://github.com/OliverHi/blueprints/blob/f010d88630fa3e0d68074905b1258e8580f3b2f6/motion_brightness_light.yaml
input:
motion_entity:
selector:
entity:
domain: binary_sensor
device_class: motion
brightness_entity:
selector:
entity:
device_class: illuminance
light_target:
name: Light(s) to control
selector:
entity:
domain: light
brightness_trigger:
name: Maximum brightness
description: Brightness trigger level. If it gets any brighter the lights will not be turned on.
default: 20
selector:
number:
min: 0
max: 1000
unit_of_measurement: lx
no_motion_wait:
description: Time to leave the light on after last motion is detected.
default: 120
selector:
number:
min: 0
max: 3600
unit_of_measurement: seconds
# If motion is detected within the delay,
# we restart the script.
mode: restart
max_exceeded: silent
# making the input variable usable in the condition
variables:
lights: !input "light_target"
platform: state
entity_id: !input motion_entity
to: "on"
- condition: or
conditions:
- "{{ expand(lights.entity_id) | selectattr('state', '==', 'on') | list | count > 0 }}" # some lights in the group are on
- condition: numeric_state
entity_id: !input brightness_entity
below: !input brightness_trigger
- service: light.turn_on
target: !input light_target
- wait_for_trigger:
platform: state
to: "off"
- delay: !input no_motion_wait
- service: light.turn_off
