I configured my device as detatched switch so that my smart bulb is always on. I want that my shelly 1L virtually controlls my light bulb via home assistant. Under I/O actions in the shelly mode I tried setting the webhook from an automation however that starts with https:// and shelly only accepts http://. Do you have any ideas what I can try?
There’s a binary sensor that monitors the Shelly switch state. Use a state trigger to monitor that and control your lights as you wish in the actions of the automation.
Thanks! The binary sensor was deactivated by defaullt. After I activated it, it did exactly what I wated it to do. However after 25 minutes the shelly turns off and goes offline (maybe overheating), so I just wired the live and ground together and stuck a tradfri dimmer next to the light switch.
