There are some guides on here for controlling internet connected Midea Air Conditioners from HA. However there are a lot of people with just normal IR units.
I linked mine in about 18 months ago with using Tasmota IR and HA. I finally got round to writing up how I did it.
Hi , Yes the link is in 404 heaven but I dnt think that is related to what you want to do
Just a question , what is "Sor conditioner " ? do you mean normal air conditioner ?
May I also ask why do you need it to be battery powered ? Is it a location issue ?
You can just attach a power bank to the universal remote and it will work .
If you are looking for a good IR universal remote that works well with HA then try
broadlink brand which I have tested but unfortunately i am not sure they have
a battery powered model
All you need I have written above , its very cheap so no need to make it a big deal .
If you attach it to the ceiling then how would charge the battery ? Unless you are
spider man then just get what the guys in the forum tell you BUT make sure you
check the reviews and specs before you buy anything because everyone have
different needs and some of the guys here are technical so you might get a good advice that
is somewhat difficult to implement .
Do you have a technical background ? If you do then you will be fine
As the guys told , you can use a power bank in the same way , just glue it together with the remote
OR get a proper project box and hock it to the ceiling and add your stuff inside .
A friend of mine has something like this where he needed 5 V in the ceiling , what we did is just add mobile
charger inside the lamp fixture and got 5v to his device , might be you can do the same
