It would be nice if I didn’t have to change every time I log in under the tab control panel overview (default) so that I can choose and lock to my own control panel Roy’s control panel. Would be grateful if you could arrange this! Thanks in advance.
As I tried to describe, I want to avoid changing from overview default every time I log in to Home Assistant, so that instead get Roy’s control panel to appear by default. The problem is that I have already done this, but then when log in next time, it has returned to the overview default! Surely this must be a bug in that case? This is what I want them to fix!
