Uses my Bifrost project (a link from MQTT to Pixelblaze controllers) and ZHA-attached Hue Dimmer Switches to let you cycle through patterns in a pixelblaze using the dimmer switch on button, turn off the strip with the off button, and change brightness as expected. You need to run Bifrost, instructions for which can be found at Docker
blueprint:
domain: automation
name: Bifrost actions with Hue dimmer switches (RWL021 and RWL022)
description: >
Use Bifrost without the hue bridge, at the moment this just sends messages directly
corresponding to the buttons on the dimmer switch, the latest bifrost container
listens to these messages and talks to the pixelblaze controllers
input:
zha_device_21:
description: Switch to use to control pixelblaze (RWL021), use either this or the RWL022 entry below. If both are specified this will be used in preference.
selector:
device:
filter:
integration: zha
model: RWL021
entity:
- domain: sensor
device_class: battery
multiple: false
default: null
zha_device_22:
description: Switch to use to control pixelblaze (RWL022)
selector:
device:
filter:
integration: zha
model: RWL022
entity:
- domain: sensor
multiple: false
default: null
pixelblaze_switch:
name: Pixelblaze switch name
description: Should match the switch name in the bifrost configuration
selector:
text:
multiline: false
type: text
default: ''
mode: queued
max_exceeded: silent
variables:
device_id_21: !input zha_device_21
device_id_22: !input zha_device_22
device_id: >
{% if device_id_21 is defined and device_id_21!=None %}
{{ device_id_21 }}
{% else %}
{{ device_id_22 }}
{% endif %}
- platform: event
event_type: zha_event
condition: '{{ trigger.event.data.device_id == device_id }}'
- variables:
pixelblaze_switch: !input pixelblaze_switch
command_type: '{{ trigger.event.data.command }}'
- choose:
- conditions: '{{ command_type == "on_press" }}'
sequence:
- service: mqtt.publish
qos: 0
retain: false
topic: 'bifrost/{{ pixelblaze_switch }}/on'
- conditions: '{{ command_type == "off_press" }}'
sequence:
qos: 0
retain: false
topic: 'bifrost/{{ pixelblaze_switch }}/off'
- conditions: '{{ command_type == "up_press" or command_type == "up_hold" }}'
sequence:
qos: 0
retain: false
topic: 'bifrost/{{ pixelblaze_switch }}/up'
- conditions: '{{ command_type == "down_press" or command_type == "down_hold" }}'
sequence:
qos: 0
retain: false
topic: 'bifrost/{{ pixelblaze_switch }}/down'
