I learned all the commands, temperature, heat, cold, etc. And, of course, go up to Temp, or download.
Mini central air conditioning - something simply unsophisticated
There is a custom version that does dual (heat and cool) as well. Dual Thermostat Card
I have improved on my previous version for making my dumb daikin airconditioner smart.
Basic idea is to use input_selects to choose the settings (mode/temp/fan speed) you want. Learn the broadlink IR codes for every AC setting you want available and save them as scripts with formulaic names. A template sensor uses the input_select settings to show the correct script. Turning on an input_boolean, triggers an automation. The automation action turns on the correct script, causing the correct IR Code to be sent to the AC. Make a template switch which has turn_on turning on the input_boolean, and turn off turning on the off script.
This is neat. Thanks for sharing.
Do you then digest the input booleans in automations? Care to share?
Am also curious about your condensation chance sensor… I could see some use for this!
I use something similiar as @zoogara - Instead of purchasing a Broadlink I’m using a Nodemcu to send the IR codes. I’ve also attached a temperature/humidity sensor which sends data back to my HA. The Nodemcu is communicating via MQTT. Works great and the whole set up is no more that $4 per AC.
( I cannot figure out how to change the temperature to F, i have my units set to metric as i need it in celsius for my 3d printer cards.)
Nice. I use the Daikin component. In Lovelace, the card defaults to the standard thermostat card. Unfortunately, I can’t set things like fan speed via these. May need to come up with a custom card for it…
Hello, thx for your reply,
And yes, my ac appears in this list, I have a gree ac.
I am also able to learn the remote codes.
What I can’t figure out os how to create the entities/service/devices ao I can create the ac card amd add the controls to it.
Your device code should match the one for your A/C, and ensure it exists in /config/custom_components/smartir/codes/climate. Choose a suitable sensor for temp and humidity, if you don’t have these I believe you can leave them out.
