The integration of the 315 MHz RGB spotlight control was achieved by listening to the 315 MHz frames for each button on the remote control and then replaying these frames via a 315 MHz transmitter. Here is the ESPHome code:
# 315 MHz — Émetteur spot LED RGB
# GPIO25
remote_transmitter:
- id: rc_transmitter
pin:
number: GPIO25
carrier_duty_percent: 100%
non_blocking: false
# BUTTON — Commande spot LED RGB 315 MHz
# transmit_raw — T=420µs mesuré sur télécommande d'origine
# Format : [bit_burst, bit_silence, ...] + [sync_burst, -sync_silence]
button:
# 010101010101010111001111
on_press:
- remote_transmitter.transmit_raw:
transmitter_id: rc_transmitter
code: [420,-1260, 1260,-420, 420,-1260, 1260,-420, 420,-1260, 1260,-420, 420,-1260, 1260,-420,
1260,-420, 1260,-420, 420,-1260, 420,-1260, 1260,-420, 1260,-420, 1260,-420, 1260,-420,
420,-11400]
repeat:
times: 5
wait_time: 40ms
# 010101010101010100111100
on_press:
420,-1260, 420,-1260, 1260,-420, 1260,-420, 1260,-420, 1260,-420, 420,-1260, 420,-1260,
420,-11400]
repeat:
times: 5
wait_time: 40ms
# 010101010101010111110000
on_press:
1260,-420, 1260,-420, 1260,-420, 1260,-420, 420,-1260, 420,-1260, 420,-1260, 420,-1260,
420,-11400]
repeat:
times: 5
wait_time: 40ms
# 010101010101010100111111
on_press:
420,-1260, 420,-1260, 1260,-420, 1260,-420, 1260,-420, 1260,-420, 1260,-420, 1260,-420,
420,-11400]
repeat:
times: 5
wait_time: 40ms
# 010101010101010111000011
on_press:
1260,-420, 1260,-420, 420,-1260, 420,-1260, 420,-1260, 420,-1260, 1260,-420, 1260,-420,
420,-11400]
repeat:
times: 5
wait_time: 40ms
# 010101010101010100001111
on_press:
420,-1260, 420,-1260, 420,-1260, 420,-1260, 1260,-420, 1260,-420, 1260,-420, 1260,-420,
420,-11400]
repeat:
times: 5
wait_time: 40ms
# 010101010101010111111100
on_press:
1260,-420, 1260,-420, 1260,-420, 1260,-420, 1260,-420, 1260,-420, 420,-1260, 420,-1260,
420,-11400]
repeat:
times: 5
wait_time: 40ms
# 010101010101010111110011
on_press:
1260,-420, 1260,-420, 1260,-420, 1260,-420, 420,-1260, 420,-1260, 1260,-420, 1260,-420,
420,-11400]
repeat:
times: 5
wait_time: 40ms
# 010101010101010111111111
on_press:
1260,-420, 1260,-420, 1260,-420, 1260,-420, 1260,-420, 1260,-420, 1260,-420, 1260,-420,
420,-11400]
repeat:
times: 5
wait_time: 40ms
# 010101010101010111000000
name: Spotlight Blue&Cyan
on_press:
1260,-420, 1260,-420, 420,-1260, 420,-1260, 420,-1260, 420,-1260, 420,-1260, 420,-1260,
420,-11400]
repeat:
times: 5
wait_time: 40ms
# 010101010101010100110011
on_press:
420,-1260, 420,-1260, 1260,-420, 1260,-420, 420,-1260, 420,-1260, 1260,-420, 1260,-420,
420,-11400]
repeat:
times: 5
wait_time: 40ms
# 010101010101010100000000
name: Spotlight FOUR SEASONS
on_press:
420,-1260, 420,-1260, 420,-1260, 420,-1260, 420,-1260, 420,-1260, 420,-1260, 420,-1260,
420,-11400]
repeat:
times: 5
wait_time: 40ms
# 010101010101010101000000
on_press:
420,-1260, 1260,-420, 420,-1260, 420,-1260, 420,-1260, 420,-1260, 420,-1260, 420,-1260,
420,-11400]
repeat:
times: 5
wait_time: 40ms
# 010101010101010100010000
on_press:
420,-1260, 420,-1260, 420,-1260, 1260,-420, 420,-1260, 420,-1260, 420,-1260, 420,-1260,
420,-11400]
repeat:
times: 5
wait_time: 40ms
