Currently a work-in-progress, don’t use this until this notice is removed!!
Basing this off of Target temperature adjustment depending on second temperature sensor, from @nevesenin. My use case is to allow for conditional use of this automation (i.e., at the end of the day, I go into the master bedroom and shut the door, now I want the temperature sensor in my bedroom to control the main thermostat, until I wake up in the morning and exit the room).
blueprint:
name: Control thermostat using remote temperature sensor
description: >
Basing this off of (https://community.home-assistant.io/t/target-temperature-adjustment-depending-on-second-temperature-sensor/297287), from @nevesenin. My use case is to allow for conditional use of this automation (i.e., at the end of the day, I go into the master bedroom and shut the door, now I want the temperature sensor in my bedroom to control the main thermostat, until I wake up in the morning and exit the room).
domain: automation
input:
temperature_sensor:
description: This sensor will be used as the source.
selector:
entity:
domain: sensor
device_class: temperature
thermostat:
description: The thermostat to set target temperature
selector:
entity:
domain: climate
trigger_sensors:
description: Trigger an update on these additional trigger state changes.
selector:
entity:
domain: sensor
target_temperature:
name: Target temperature
description: Target temperature of the thermostat
selector:
number:
min: 45
max: 85
step: 0.5
unit_of_measurement: "°F"
default: 72
variables:
thermostat: !input thermostat
temperature_sensor: !input temperature_sensor
target_temperature: !input target_temperature
actual_temperature: "{{ states(temperature_sensor) | float }}"
calculated_adjustment: "{{ target_temperature - actual_temperature }}"
calculated_target_temperature: "{{ ( ( ( target_temperature + calculated_adjustment ) * 2 ) | round ) / 2 }}"
- platform: state
entity_id: !input thermostat
attribute: "{{ current_temperature_attribute }}"
- platform: state
entity_id: !input temperature_sensor
condition: "{{ calculated_adjustment != 0 }}"
- service: system_log.write
message: >
{{ thermostat }} has temp difference of {{ calculated_adjustment }}. Setting target temperature to {{ calculated_target_temperature }}
level: info
logger: blueprints.nevesenin.target_temperature_adjustment
message: >
thermostat: {{ thermostat }},
temperature_sensor: {{ temperature_sensor }},
target_temperature: {{ target_temperature }},
actual_temperature: {{ actual_temperature }},
calculated_adjustment: {{ calculated_adjustment }},
calculated_target_temperature: {{ calculated_target_temperature }}
level: debug
- service: climate.set_temperature
temperature: "{{ calculated_target_temperature }}"
entity_id: "{{ thermostat }}"
mode: single
