Could I ask you if you have got an Amazon dot and if you have set up custom skills?
Also who is your ISP? as mine is Virgin Media and I cannot forward internal ports to external ports.
Virgin is my isp⌠No custom skill either, just the emulated hue component fur hone assistant.
So I have finally managed to connect my tivo box to my network and I have run the commands from terminal on my mac using the ip address of my tivo box but it doesnt seem to like it. Here is what I did:
IRCODE STANDBY | telnet 192.168.0.18 31339
and it spits out:
Trying 192.168.0.18âŚ
Connected to 192.168.0.18.
Escape character is â^]â.
Connection closed by foreign host.
Any idea on this? Did you have similar issues to mine?
Right soâŚ
From command line on my mac if I say "telnet 192.168.0.18 31339â It logs me into the session and then if I say âSETCH 144â it changes the channel to 144 but it doesnt like: echo âSETCH 144| telnet 192.168.0.18 31339â
Try adding as a switch⌠I dud come across that error too. Think it should work in a switch.
Try that and let me know how you get on.
. Youâre very close rho!
I have gone straight to HA added the following in my configuraton.yaml:
platform: command_line
switches:
youview_on:
command_on: 'echo IRCODE STANDBY | telnet 192.168.0.18 31339'
command_off: 'echo IRCODE STANDBY | telnet 192.168.0.18 31339'
friendly_name: Virgin On
but get errors:
17-03-18 16:05:22 ERROR (Thread-1) [homeassistant.util.yaml] while parsing a block collection
in "/home/homeassistant/.homeassistant/configuration.yaml", line 61, column 3
expected <block end>, but found '?'
in "/home/homeassistant/.homeassistant/configuration.yaml", line 182, column 3
17-03-18 16:05:22 ERROR (MainThread) [homeassistant.bootstrap] Error loading /home/homeassistant/.homeassistant/configuration.yaml: while parsing a block collection
Any idea where am I going wrong?
Thanks.
Yamls well temperamental.
Looks like you need an extra space on the command on.
Youâve prob got a space somewhereâŚ
Whsts happening on these lines?
182 - assume this is the switch?
61
I have set my MQTTs as a switch and therefore I have to put the command line switch as:
- platform: command_line
switches:
youview_on:
but now I get an error saying:
ERROR (MainThread) [homeassistant.config] Invalid config for [switch.command_line]: expected a dictionary for dictionary value @ data['switchesâ]. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/switch.command_line/
Right I have managed to set it up in my configuration.yaml by doing the following:
switches:
youview_on:
but when I send turn off the Virgin Switch nothing happens instead if I check my log it gives me the following error:
17-03-18 17:04:09 ERROR (Thread-8) [homeassistant.components.switch.command_line] Command failed: echo IRCODE STANDBY | telnet 192.168.0.18 31339
Hello mate
Do you get any errors like mine?
Also how have you setup your command line? Do I to have to install anything on my pi for telnet to work?
Thanks.
Yeah i get errors like yours in my log but mine actually changes the channelâŚ
thinking back i think i did install telnet⌠give that a go⌠although sounds like you already have it if you can open a sessionâŚ
sudo apt-get install telnetd
you can write the equivalent in sh but i found there to be a delay when having to open script, which is why i used the cmd line approach as its far quicker.
17-03-14 21:25:02 ERROR (Thread-6) [homeassistant.components.switch.command_line] Command failed: echo IRCODE STANDBY | telnet 192.168.0.10 31339
is what i get, but the command still works.
What version of HA are you on?
paste this on cmd line:
Does it do anything? it should change the channel but also print this to the screen:
pi@raspberrypi:~ $ echo IRCODE RECORD | telnet 192.168.0.10 31339
Trying 192.168.0.10...
Connected to 192.168.0.10.
Escape character is '^]'.
Id focus on just running the commands straight on the cmd line first, then when it works just copy that code to your switch.
It works after installing telnet ! Thanks !
Now to add channels do I have to add the code below again:
switches:
youview_on:
command_on: 'echo SETCH 144 | telnet 192.168.0.18 31339'
friendly_name: Itv
Do I have to change youview_on
to something else?
Yeah you can do if you want, but it cant have any spaces in itâŚthe switch will then be called switch.youview_on which is what they will be referred to as entities. So best change them to something more meaningful i guess i just havent yet
Hereâs most of mine if you want to use them:
switch youview_off:
switches:
youview_off:
command_on: 'echo IRCODE STANDBY | telnet 192.168.0.10 31339'
command_off: 'echo IRCODE STANDBY | telnet 192.168.0.10 31339'
friendly_name: Virgin off
switch youview_on:
switches:
youview_on:
switch ok:
switches:
ok:
command_on: 'echo IRCODE SELECT | telnet 192.168.0.10 31339'
command_off: 'echo IRCODE SELECT | telnet 192.168.0.10 31339'
friendly_name: Ok
switch record:
switches:
record:
command_on: 'echo IRCODE RECORD | telnet 192.168.0.10 31339'
command_off: 'echo IRCODE RECORD | telnet 192.168.0.10 31339'
friendly_name: Record
switch pause:
switches:
pause_youview:
command_on: 'echo IRCODE PAUSE | telnet 192.168.0.10 31339'
command_off: 'echo IRCODE PAUSE | telnet 192.168.0.10 31339'
friendly_name: Pause
switch mute:
switches:
mute_amp:
command_on: 'curl "https://autoremotejoaomgcd.appspot.com/sendmessage?key==Mute"'
command_off: 'curl "https://autoremotejoaomgcd.appspot.com/sendmessage?key=Mute"'
friendly_name: Mute
switch surround:
switches:
surround_sound:
command_on: 'curl "https://autoremotejoaomgcd.appspot.com/sendmessage?key==Surround"'
command_off: 'curl "https://autoremotejoaomgcd.appspot.com/sendmessage?key==Mute"'
friendly_name: Surround sound
switch back:
switches:
back_youview:
command_on: 'echo IRCODE BACK | telnet 192.168.0.10 31339'
command_off: 'echo IRCODE BACK | telnet 192.168.0.10 31339'
friendly_name: Back
switch play:
switches:
play_youview:
command_on: 'echo IRCODE PLAY | telnet 192.168.0.10 31339'
command_off: 'echo IRCODE PLAY | telnet 192.168.0.10 31339'
friendly_name: Play
switch stop:
switches:
stop_youview:
command_on: 'echo IRCODE STOP | telnet 192.168.0.10 31339'
command_off: 'echo IRCODE STOP | telnet 192.168.0.10 31339'
friendly_name: Stop
switch fast_forward:
switches:
fast_forward:
command_on: 'echo IRCODE FORWARD | telnet 192.168.0.10 31339'
command_off: 'echo IRCODE FORWARD | telnet 192.168.0.10 31339'
friendly_name: Fast forward
switch rewind:
switches:
rewind:
command_on: 'echo IRCODE REVERSE | telnet 192.168.0.10 31339'
command_off: 'echo IRCODE REVERSE | telnet 192.168.0.10 31339'
friendly_name: Rewind
switch volumeup:
switches:
volume_up:
command_on: 'curl "https://autoremotejoaomgcd.appspot.com/sendmessage?key=Volumeup"'
command_off: 'curl "https://autoremotejoaomgcd.appspot.com/sendmessage?key==Volumeup"'
friendly_name: Volume up
switch volumedown:
switches:
volume_down:
command_on: 'curl "https://autoremotejoaomgcd.appspot.com/sendmessage?key==Volumedown"'
command_off: 'curl "https://autoremotejoaomgcd.appspot.com/sendmessage?key==Volumedown"'
friendly_name: Volume down
switch channel_28:
switches:
e4_youview:
command_on: 'echo SETCH 144 | telnet 192.168.0.10 31339'
command_off: 'echo SETCH 144 | telnet 192.168.0.10 31339'
friendly_name: E4
switch channel_101:
switches:
101_youview:
command_on: 'echo SETCH 108 | telnet 192.168.0.10 31339'
command_off: 'echo SETCH 108 | telnet 192.168.0.10 31339'
friendly_name: Channel one
switch channel_102:
switches:
102_youview:
command_on: 'echo SETCH 109 | telnet 192.168.0.10 31339'
command_off: 'echo SETCH 109 | telnet 192.168.0.10 31339'
friendly_name: Channel two
switch channel_103:
switches:
103_youview:
command_on: 'echo SETCH 113 | telnet 192.168.0.10 31339'
command_off: 'echo SETCH 113 | telnet 192.168.0.10 31339'
friendly_name: Channel three
switch channel_104:
switches:
104_youview:
command_on: 'echo SETCH 141 | telnet 192.168.0.10 31339'
command_off: 'echo SETCH 141 | telnet 192.168.0.10 31339'
friendly_name: Channel four
switch channel_105:
switches:
105_youview:
command_on: 'echo SETCH 150 | telnet 192.168.0.10 31339'
command_off: 'echo SETCH 150 | telnet 192.168.0.10 31339'
friendly_name: Channel five
switch comedy_central:
switches:
comedy_central:
command_on: 'echo SETCH 132 | telnet 192.168.0.10 31339'
command_off: 'echo SETCH 132 | telnet 192.168.0.10 31339'
friendly_name: Comedy Central
switch dave:
switches:
dave:
command_on: 'echo SETCH 127 | telnet 192.168.0.10 31339'
command_off: 'echo SETCH 127 | telnet 192.168.0.10 31339'
friendly_name: Dave
I have also added them to a group and changed the icon of each switch using customize.yaml
customize: !include customize.yaml
switch.youview_off:
icon: mdi:power
switch.youview_on:
icon: mdi:power
switch.surround_sound:
icon: mdi:speaker
switch.101_youview:
icon: mdi:numeric-1-box
switch.102_youview:
icon: mdi:numeric-2-box
switch.103_youview:
icon: mdi:numeric-3-box
switch.104_youview:
icon: mdi:numeric-4-box
switch.105_youview:
icon: mdi:numeric-5-box
switch.e4_youview:
icon: mdi:remote
switch.comedy_central:
icon: mdi:remote
switch.dave:
icon: mdi:remote
switch.kodi_input_amp:
icon: mdi:amplifier
switch.ok:
icon: mdi:bookmark-check
switch.pause_youview:
icon: mdi:pause
switch.play_youview:
icon: mdi:play
switch.stop:
icon: mdi:stop
switch.record:
icon: mdi:record-rec
switch.testing_hyperion:
icon: mdi:power
switch.tv_input_amp:
icon: mdi:amplifier
switch.fast_forward:
icon: mdi:step-forward
switch.rewind:
icon: mdi:rewind
switch.mute_amp:
icon: mdi:volume-off
switch.back_youview:
icon: mdi:keyboard-backspace
switch.volume_up:
icon: mdi:volume-high
switch.volume_down:
icon: mdi:volume-low
then include a group for your home page:
youview_control:
icon: mdi:kettle
entities:
- switch.youview_on
- switch.youview_off
- switch.pause_youview
- switch.play_youview
- switch.stop_youview
- switch.101_youview
- switch.102_youview
- switch.103_youview
- switch.104_youview
- switch.105_youview
- switch.dave
- switch.comedy_central
- switch.e4_youview
- switch.ok
- switch.back_youview
- switch.record
- switch.rewind
- switch.fast_forward
amp_control:
entities:
- switch.surround_sound
- switch.volume_up
- switch.volume_down
- switch.mute_amp
- switch.kodi_input_amp
- switch.tv_input_amp
Sounds like youâre all sorted now mate! Now start adding all the buttonsâŚ
i have noticed that you need to switch the virgin box off twice to take it into standby straight away which is a little annoying, if you hit it once a message appears for 5 secs before it actually goes into standyâŚ
Thanks alot for your help. Its up and running.
Just a quick one with the volume. Do you say to Alexa turn the "Volume Up Onâ ?
After installing telnet by âsudo apt-get install telnetdâ
I tried the command: âecho IRCODE STANDBY | telnet 192.168.0.11 31339â
But I get the error: -bash: telnet: command not found
What could be wrong?
Yep, afraid so. Its a bit whackâŚ
@Kimpan
try sudo apt-get install telnet
It sounds like telnet didnt install properly or isnt installed. you only get that error when it cant find the
correct program. Or its still installinâŚ
have you upgraded your pi OS recently?
sudo apt-get update
sudo apt-get dist-upgrade
try
to see if you can establish a session first
I have now done the following:
sudo apt-get update
Then when doing the âtelnet 192.168.0.11 31339â
It gets stuck on âTrying 192.168.0.11âŚâ
and finally:
telnet: Unable to connect to remote host: Connection timed out
Do I need to do something on the TIVO box for telnet to work?
Sounds like your box isnât online or the ip is wrong gâŚ
Hi @Rich_Paul
Just a quick question: when you ask alexa to turn on BBC News do you actually say âBBC Newsâ or? because when I ask her to turn on BBC News it turns on the radio.
Do you experience the same?
