Control ventilation from web interface, create virtual thermostat
This way over my league, but its had been nice to get I wok.
I haven’t had many week with HA and I’m cant coding. Most of what I have achieve, is basically google and forum, copy code and manage to get I work.
Im not expect someone is going to write the hole code, but its been nice to get started…
I have today an Exvent ventialtion ( https://www.exvent.no/product/pelican-z/ ) with eAir. I can do basic control and graph reading from web interface ( https://my.enervent.com/ ).
The goal is simple, is to controlling the ventilation unit true HA with using virtual thermostats and cards. The problem is, how to collect data and set data ?
After logged in, I have an huge copy of the small control panel at the wall.
I can change temperature, boost and overpressure with just a click. Change effect in milliseconds. Im also able to read a lot of statistic and graph from Measurements, data I want to log in HA and create lovelace graph.
The way from here is defuse, but I need a way to let HA login to the page and grab information and transfer that to virtual thermostat. Also function, as +/- temp, boost, overpressure, and some file.
index
type or paste code <!DOCTYPE html>
<!-- <html manifest="cache.manifest"> -->
<html>
    <head>
        <title>Enervent eAir web</title>
        <meta http-equiv="Content-Type"  content="text/html; charset=UTF-8" />
        <meta name="apple-mobile-web-app-capable" content="yes">
        <meta name="viewport" content="initial-scale=1, maximum-scale=3">
        <meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1" >
        <link rel="icon" href="lib/ensto/eapi-hyco-ui/img/favicon.ico" sizes="16x16 24x24 32x32 48x48 64x64" type="image/vnd.microsoft.icon">
        <link rel="stylesheet" href="lib/ensto/eapi-hyco-ui/css/eair-web.css" />
        <script type="text/javascript" src="lib/ensto/eapi-hyco-ui/js/eair-web.js"></script>
        <script type="text/javascript" src="/socket.io/socket.io.js"></script>
    </head>
    <body ondragover="return false">
        <script>
            function dropHandler(ev) {
                ev.preventDefault();
                var key = Object.keys(eAPI.fn.ucpCore.devices)[0];
                var file;
                for (var i = 0; i < ev.dataTransfer.files.length; i++) {
                    file = ev.dataTransfer.files[i];
                var formData = new FormData();
                formData.append("file", file);
                formData.append("key", key);
                eAPI.update(formData);
            try {
                if (!window.console) {var console = {};}
                if (!console.log) {console.log = function() {};}
                if (!document.addEventListener) {
                    document.write('<div id="notsupp">Browser not supported.</div>');
                } else {
                    eAPI.core.loader.onloadCb[0]();
                    eAPI.core.loader.onloadCb[1]();
            } catch (e) {
                console.log('error:', e);
        </script>
        <noscript><br>JavaScript is off. Please enable to view full site.</noscript>
    </body>
</html>
here
eair.web.js ( link)
socket.io.js
