Control xiaomi air purifier with google home over home assistant cloud
I use the home assistant on a RPI. I also connected the home assistant cloud and I can turn the xiaomi air purifier on and off with google assistant. But I can only turn it on (in auto mode) or off and not in favorite mode (to clean right before bedtime).
Is there a way to control the fan speed with google assistant?
And (a little bit) unrelated is it possible to get the air quality readings via google assistant?
Thanks in advance.
I’ve been trying to determine this recently also, I’m not sure how to control the Air Purifier speed via Google Assistant.
Has anyone succeeded with this?
I’ve tried:
  • “Set Air Purifier speed to Favorite”
  • “Air Purifier speed”
When I try “What is the Air Purifier speed?” I get a response “I can’t reach the Air Purifier right now”
However, I can turn on/off the device using:
  • “Turn on Air Purifier”
  • “Turn off Air Purifier”
