I have a Logitech Harmony set up so that I can have a it linked to HA and turn on my TV, Yamaha 2060 receiver, changed the mode - say the XBOX hdmi slot - and then change the input on the AV receiver. I’m not sure how long Logitech will still support Harmony so I want to do this via a script in HA. I can’t find the YAmaha as a device but I can’t seem to find a way of changing the inputs so it changes everything to the Play X-box setting ie change the input etc on the Yamaha AV receiver. Can this be done ?
Have you checked to see if the Yamaha network receiver integration supports it?
According to the datasheet it supports MusicCast.
I use a mixture of both the Network Receiver and MusicCast integrations for my RX-V685.
Network integration allows renaming and hiding of sources, MusicCast does not.
MusicCast has a lot more controls.
Both have media players you can control in automations and scripts.
Thanks - yes I have musiccast linked but can’t seem to find a way to change sources - and HDMI slots - in script etc. Just can’t seem to figure out how to do it
https://www.home-assistant.io/integrations/media_player/#service-media_playerselect_source
- service: media_player.select_source
entity_id: media_player.yamaha_2060
source: HDMI1
