Developers wanted to integrate the Open BCI module into Home Assistant to control your house. Instruction can be found here:
So you can control your house with the blink of an eye. The new version of the Open BCI WIFI shield should be available in near future. With the OpenBCI WIFI shield it is possible to have an MQTT stream from the WIFI shield to Home Assistant.
«The hardware team has put the wifi shield on the list of near-term projects. Solution testing will soon be underway.»
WiFi Shield availablity in store? (need higher sample rate) — OpenBCI Forum
