***Updated and resolved:
The answer was to use a DAT (Device Access Token) url that is provided in the CBW cloud account and don’t bother with the api.
I’m using a ControlbyWeb X-410 relay/sensor module to read temps using modbus on the local network which works well. I really need to have this accessible via the cloud as it is in an RV. I assume the best way to do this is with Restful sensors but it is way outside my expertise and after several hours of reading, configuring and testing it’s clear I need some help.
This is what I have in when trying to test one sensor.
rest:
- authentication: basic
username: "xxxxxx"
password: "xxxxxxx"
scan_interval: 60
resource: https://api.controlbyweb.cloud/api/v1/auth/token/
name: "Hose Reel Temperature"
device_class: temperature
unit_of_measurement: °F
json_attributes_path: "$.customState.json"
value_template: "{ { value_json.hoseReel } }"
I’ve gotten it so there are no errors in the logs but just returns “unknown” for data. Really appreciate any help in getting me in the right direction.
Thanks!
