What you are experiencing is a known problem from HUE integration. They cannot be used with a transition attribute to turn on/off their lights. So the problem is that ControllerX sends the transition attribute in all calls by default. However, you can change this by adding to each of the configurations:
add_transition_turn_toggle: false
This will remove the transition attribute from thr calls when turning on/off. In fact, you can experience the same if you go to âDeveloper Tools > Servicesâ and turning on the light using the transition attribute. You can read more about this problem in Section 6 from the FAQ.
Thank you, tested it a lots of time, and I can say itâs working like a charm!
And thanks a lot for direct MQTT integration, itâs speeded up the things.
I updated everything, and I just realized, sometimes the AppDaemon get killed, with this warning:
Excessive time spent in utility loop: 2549.0ms, 14.0ms in check_app_updates(), 2535.0ms in other
I made a bigger log, and pasted here: ErrorLog - Pastebin.com
Disabled everything else, and only ControllerX running with 2 integrations. Anyway didnât noticed any fallback with this problem, only the log is not nice
You can see a topic about that in here. The creator of AppDaemon summarises the problem. You can do what he says about the utility_delay or you can directly add production_mode to true. The latter will not check for changes in the apps.ya and you will need to restart the addon everytime. And the former will change the delay to something larger than 1 second, to check the config every 5 or 7 seconds for example.
Let me know if that fixed the problem Thanks for letting me know about the fix and I am glad that the MQTT integration works better for you, I do recommend using it too, there is a significant difference.
The mqtt is has a generic purpose, you don,c,t have to use it for z2m. If you for example already have a device that comunicates through mqtt, then you can use that. However, deCONZ does not use MQTT, but its speed is comparable to using MQTT already. The problem with the z2m integration is that listens to the state change of the sensor and that slows down the communication. deCONZ uses events and that is much faster.
Does ControllerX work with the SmartThings Integration? It seems this approach would need a webhook integration?
I have an IKEA E1810 remote paired with a smartthings hub, Iâd prefer to consolidate scene control and scripting logic in HA. The scenes defined in HA are not visible in the smartthings app. Only the IKEA Remote battery appears as an entity in HA from the smartthings integration.
Any suggestions on a workaround if this is outside the plan for ControllerX?
thanks for great solution, but I have some issue with WXCJKG13LM and IKEA Tradfri 1000 - double click bottom right button should increase the light temperature to max, but my bulb is getting cold. Holding this button works good.
Found your post on reddit and it was perfect timing as I bought the Ikea ICTCG1 controllers for half price.
Set this up last night and set up was a breeze. I do have a few issues though with this controller.
I find the actions arenât smooth or they arenât reading correctly. Whether I am turning left or right sometimes it doesnât read or it is very delayed. Same goes for the quick turns. I have tried both MQTT and Z2M integrations and I find Z2M to be more responsive but still not 100%. Would you have any suggestions?
Hope you can help. I love these rotating dimmers but not liking how choppy they are. Hope I can fix them.
Edit: Had a problem with using media player integration but I figured it out. Didnât realise the class changes as well
If I undertood well, you integrated this controller with z2m, right? As far as I know these controllers are a little bit more laggy than the symfonisk ones (E1744) which are like the ânewâ version of the one that you bought. However, I would recommend you to set it up with the MQTT integration, something like this:
This will change how often ControllerX will call HA to change the brightness of the light and the steps for the change. By default these 2 attribute are much âlaggyâ since depending on the network, this could be too much. So you can play around with those 2 parameters. Also, you will need to check the mqtt topic of that controller on the zigbee2mqtt logs, it normally finishes with /action or /click.
Regarding the use of this controller for a media plaer is not yet implemented. I will add support to it, since this controller does not have click action, I will leave as default that quick right will call the play action and quick left will call pause action.
I just created a beta release with the support for the MediaPlayer controller for the ICTCG1 dimmer. You wonât see yet the documentation for it since it is not a stable release. You can mark âShow betaâ in HACS and you will see v3.1.0b0.
So It is better but not 100%. The dimming is better but sometimes when Im rotating and I stop, it will continue to dim. The other issue I have is If I do a quick rotate left or right, it takes me a couple of tries for it the light to turn on and off.
I think youâre right and I will have to play with the the 2 parameters to find that sweet spot.
Just noticed you made the beta! Thank you so much. I will try that out shortly.
To all the Canadianâs out there, Happy Canada Day!
Again, Thank you for making this release! You have saved me lots of time trying to wrap my head on integrating these dimmers/switches.
I am not Canadian, but happy Canada day I think the problem you are experimenting with the light dimming down without stopping it is ecause the controller sends a lot of rotation actions and it might happen that the last one is no a rotation_stop. I will recomend you to check the logs on z2m logs, so you will see the events that the controller fires, this is shy the symfonisk one is much better for this.
Good luck with it and let me know about the media player controller integration, you might have the same problems with the media player volume that you have with the brightness of the light, the idea behind is the same one.
