@Carlos_Luis I have it running in docker fine. What tag are you pulling? I’m using dev and it works well. I think it might not be happy with your ha_url and dash_url as I think it’s expecting http prefix. This is mine using HA and AppDameon in separate containers on the same machine
You will need to set up a custom controller for each device you want controlled and then map those buttons to that device. You should have one appdaemon app for each device. See the docs on customcontrollers here
The key mappings vary for each integration (zha,deconz,z2m) and can be found here.
Dear @sreknob thanks a lot for sharing your config with me. It help a little bit. But I’m still getting some issues.
Thanks as well @xaviml for your great support, although for me isn’t working yet, but I’m pretty sure I will get it soon
First I would like to explain you my setup:
Intel Nuc i3 8th generation with 8GB RAM running Ubuntu Server with Docker CE
I have HA up and running under docker with the following docker-compose.yaml file:
Yes the USB devices are #commented because as far as I know I don’t need them in HA. But maybe I’m wrong with that.
I have the ConBee 2 as ZigBee USB Sniffer up and running under docker as well, hereby my docker-compose.yaml file:
# Deconz
version: '3'
services:
deconz:
container_name: deconz_conbee
image: marthoc/deconz
restart: unless-stopped
network_mode: host
environment:
# You can access Deconz at this port
DECONZ_WEB_PORT: 8081
DECONZ_WS_PORT: 8088
# Set VNC_MODE to 0 to disable it completely
DECONZ_VNC_MODE: 0
DECONZ_VNC_PORT: 5900
DECONZ_VNC_PASSWORD: "${VNC_PASSWORD}"
TZ: "Europe/Amsterdam"
volumes:
- /etc/localtime:/etc/localtime:ro
- /etc/timezone:/etc/timezone:ro
# Replace <local path> with a path where all deconz config will be stored.
- /home/luiscarlos/dockerdisco2/volumes/deCONZ-conbee:/root/.local/share/dresden-elektronik/deCONZ
devices:
- "/dev/ttyACM0:/dev/ttyACM0"
The docker-compose.yaml from my AppDaemon under docker:
appdaemon:
container_name: AppDaemon
image: acockburn/appdaemon:latest
environment:
TZ: "Europe/Madrid"
HA_URL: "3.0.0.232:8123"
TOKEN: "eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJjMGEzMzc4MjNhMWU0NmFmYmYzYWMyNzExOTdlMGQxYSIsImlhdCI6MTU4MjI3NTQ3NiwiZXhwIjoxODk3NjM1NDc2fQ.KvhquQEY6zjJJ_8tikYJDtm4XvjzseRT-614BfuiuqE"
DASH_URL: "3.0.0.232:5050"
ports:
- "5050:5050"
volumes:
# Set which local directory will contain all your app daemon configuration
- /home/luiscarlos/dockerdisco2/volumes/AppDaemon/conf:/conf
Here my AppDaemon/config/appdaemon.yam config file:
At this point, “http” before the my local IP of HA will be missed after closing the file and restart the docker container “AppDaemon”. Example: ha_url: http://3.0.0.232:8123 will be 3.0.0.232:8123
With this setups: HA is working fine, deConz for my ConBee 2 USB ZigBee Sniffer is working good as well, but my container called AppDaemon is showing me the following error:
2020-02-25 17:12:42.437953 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
Once the token is created, there is no way to check if it’s correct. You could remove that one and create a new one. I would recommend you to wrap it between quotes as well, just in case.
@Carlos_Luis - change your docker compose for appdaemon to the dev tag and try again.
image: acockburn/appdaemon:dev
I looked and the appdaemon addon is pinned to 4.0.1 but they have some custom stuff going on to automatically set access to HA.
Just tried latest and 4.0.1 with my working config I posted earlier and I was getting errors. When I do a fresh pull with dev tag she fires up no problem. There must be some changes between them but I haven’t investigated it further yet. If it ain’t broke, don’t fix it, right?
Let me know how it goes!
EDIT
Two things I just noticed after looking at your config again.
Generate a new access token and use that if you’ve posted your actual token! Not sure if you have external access set up, but better safe than sorry when it comes to passwords on public forums.
I think the reason that your http:// keeps disappearing is because your docker-compose file re-writes your config on start with the “HA_URL” and “DASH_URL” that you use on the container start. To fix this, you need to change your docker compose to have the http:/// part.
appdaemon:
environment:
TZ: "Europe/Madrid"
HA_URL: "http://3.0.0.232:8123"
DASH_URL: "http://3.0.0.232:5050"
ports:
- "5050:5050"
volumes:
If you’re starting from a command line you may have to escape the URL to make it run but hopefully not.
2020-02-25 21:58:19.709953 INFO AppDaemon: AppDaemon Version 4.0.2 starting
2020-02-25 21:58:19.710061 INFO AppDaemon: Python version is 3.8.1
2020-02-25 21:58:19.710140 INFO AppDaemon: Configuration read from: /conf/appdaemon.yaml
2020-02-25 21:58:19.710221 INFO AppDaemon: Added log: AppDaemon
2020-02-25 21:58:19.710307 INFO AppDaemon: Added log: Error
2020-02-25 21:58:19.710380 INFO AppDaemon: Added log: Access
2020-02-25 21:58:19.710454 INFO AppDaemon: Added log: Diag
2020-02-25 21:58:19.719642 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2020-02-25 21:58:19.724355 INFO HASS: HASS Plugin Initializing
2020-02-25 21:58:19.724465 INFO HASS: HASS Plugin initialization complete
2020-02-25 21:58:19.724705 INFO AppDaemon: HTTP is disabled
2020-02-25 21:58:19.726304 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
2020-02-25 21:58:19.727144 WARNING AppDaemon: Threads directive is deprecated apps - will be pinned. Use total_threads if you want to unpin your apps
2020-02-25 21:58:19.729459 INFO AppDaemon: App 'Luz_Mesa_Comedor_controller_IKEA_E1810' added
2020-02-25 21:58:19.729808 INFO AppDaemon: Found 1 total apps
2020-02-25 21:58:19.729999 INFO AppDaemon: Starting Apps with 1 workers and 1 pins
2020-02-25 21:58:24.729450 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
2020-02-25 21:58:29.732236 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
2020-02-25 21:58:34.735566 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
2020-02-25 21:58:39.738679 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
The following Loop repeats every 5" : 2020-02-25 21:58:39.738679 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
I’m still a little bit lose. Don’t know why is not working yet.
Anyway, thanks for your help @sreknob@xaviml much appreciate it !!
@Carlos_Luis I see we were writing at the same time. See the updated docker-compose part.
And for posterity sake, I found the issue as to why mine is only loading with the dev branch.
Turns out there is an issue if the http interface isn’t loaded in the config. The two issues and related PRs to fix this are here and here. Looks like it will be in 4.0.2 though. Otherwise you can work around it by adding the missing http section with admin interface to appdaemon.yaml
Ohhh Right! We’re writing in this forum at the same time.
Please don’t worry about my Token, I will create a new one after solve this issue. At the moment I have no ports open, everything works locally.
You’re right now the issue seems to be solved:
2020-02-25 22:21:20.534173 INFO AppDaemon: AppDaemon is stopped.
2020-02-25 22:21:22.277444 INFO AppDaemon: AppDaemon Version 4.0.2 starting
2020-02-25 22:21:22.277594 INFO AppDaemon: Python version is 3.8.1
2020-02-25 22:21:22.277684 INFO AppDaemon: Configuration read from: /conf/appdaemon.yaml
2020-02-25 22:21:22.277767 INFO AppDaemon: Added log: AppDaemon
2020-02-25 22:21:22.277862 INFO AppDaemon: Added log: Error
2020-02-25 22:21:22.277947 INFO AppDaemon: Added log: Access
2020-02-25 22:21:22.278029 INFO AppDaemon: Added log: Diag
2020-02-25 22:21:22.289289 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2020-02-25 22:21:22.296186 INFO HASS: HASS Plugin Initializing
2020-02-25 22:21:22.296319 INFO HASS: HASS Plugin initialization complete
2020-02-25 22:21:22.296606 INFO AppDaemon: HTTP is disabled
2020-02-25 22:21:22.299511 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
2020-02-25 22:21:22.300949 WARNING AppDaemon: Threads directive is deprecated apps - will be pinned. Use total_threads if you want to unpin your apps
2020-02-25 22:21:22.315918 INFO AppDaemon: App 'Luz_Mesa_Comedor_controller_IKEA_E1810' added
2020-02-25 22:21:22.319649 INFO AppDaemon: Found 1 total apps
2020-02-25 22:21:22.319924 INFO AppDaemon: Starting Apps with 1 workers and 1 pins
2020-02-25 22:21:27.303008 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
2020-02-25 22:21:32.305591 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
2020-02-25 22:21:37.307707 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
2020-02-25 22:21:42.309730 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
2020-02-25 22:21:47.312246 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
2020-02-25 22:21:52.321493 INFO HASS: Connected to Home Assistant 0.105.3
2020-02-25 22:21:52.656239 INFO HASS: Evaluating startup conditions
2020-02-25 22:21:52.662461 INFO AppDaemon: Got initial state from namespace default
2020-02-25 22:21:54.355986 INFO AppDaemon: Scheduler running in realtime
2020-02-25 22:21:54.358606 INFO AppDaemon: Adding /conf/apps to module import path
2020-02-25 22:21:54.360253 WARNING AppDaemon: No app description found for: /conf/apps/hello.py - ignoring
2020-02-25 22:21:54.361194 INFO AppDaemon: App initialization complete
I just restarted all my containers: HA, deConz, AppDaemon but my IKEA smart button doesn’t modify any light with the following set up under volumes/AppDaemon/conf/apps/app.yaml
@Carlos_Luis - does your appdaemon log show your app Luz_Mesa_Comedor_controller_IKEA_E1810 being initialized?
Hey, now that I’ve learned about it and tried it – it looks like the http interface has a wealth of information that might be useful while troubleshooting. Add it to your config and see if it gives any clues.
By the way: why do we need this? DASH_URL: "http://3.0.0.232:5050" ??
If I try to copy and paste the URL http://3.0.0.232:5050 on my web browser nothing happens:
That’s because you don’t have any dashboards configured as you’ve commented out the helloworld app.
Turn on the admin interface and you will get it at that url - http://3.0.0.232:5050
To do that, add this to the bottom of your appdaemon.yaml file and restart appdaemon container
http:
url: http://3.0.0.232:5050
admin:
Also, I’m not sure that the controller is loaded from your logs. Why is HA losing connection? Are you restarting it? If you controller is loaded you should see it under the Apps heading in the web interface.
You can also check that it’s seeing your HA instance by looking at the Entities section.
Now the admin interface is up and running. thanks a lot!
Unfortunately my IKEA smart button doesn’t work as desired, it seems it’s not inizialized becasue I don’t see it under my HA, wich yes I restarted together with AppDaemon just in case it may help.
Now that you have AppDaemon up and running, did you install ControllerX? if you install it through HACS, you will see it will be placed in /config/appdaemon/apps/contollerx/
If you go to Developer tools > event and start listening for deconz_event do you see anything there when pressing any button? If so, can you share what you see?
