Thanks @dede34fr, but I will need the states that the controller sends when each button is pressed. I only see it supports click and not hold, but I would need to know which clicks are supported.
OK will look a that when I get it
Hi @xaviml
Thanks for the reply!
I tried the transition
attribute with the HA services homeassistant.turn_on
and even with homeassistant.turn_off
. The only difference was that bulb lighted up a little later (~2 seconds) with transition: 100
, but it did remember the last brightness state.
Additionally, I tried to change controllers and bulbs between together and noticed that E1810Controller
(the round one with 5 buttons) did remembered the ikea E27 806lumen brightness value. However the E1743Controller
(the square one with 2 buttons) behavior didnāt changed with ikea E27 1000lumen, meaning that it did not remember the brightness value when the light was turned on.
Ikea E27 806lumen supported_features
state value ā41ā (please notice that this bulb doesnāt support color change if it affects something).
Ikea E27 1000lumen supported_features
state value ā43ā (does support color_temp)
This is getting very interestingā¦=)
Sure, I could use only ControllerXās dim_up and dim_down features for E1743 and do simple HA automations to turn on/off the light, but of course it would be nice to have it all in one place.
Is there any change that the method Light.ON_FULL_BRIGHTNESS
from light_controller.py
is executed in my situation?
I got it working with the following temporary configuration:
kitchen_light_controller:
module: controllerx
class: E1743Controller
controller: sensor.MY_SENSOR_click
integration: z2m
light: light.MY_LIGHT_light
mapping:
on:
service: homeassistant.turn_on
entity_id: light.MY_LIGHT_light
Would be still nice to solve the issue/root cause Not sure could I debug somehow the code when the āonā-button is pressed from E1743.
Hiā sebul0n
Welcome to āthe land of endless possibilitiesā with your remotes
As Xavi pointed out, there been a recent change in which calls include the transition attribute.
Iāve spend MANY hours testing various setups, regarding Ikea bulbs on z2m and Ikea/Hue bulbs on Hue bridge integration. Itās NOT an easy task for Xavi to get everything right, as bulbs react diffently on same HA calls - depending on individual fw in bulbs and which integration is used.
If youāre REALLY bored , you can take a look at my latest bug report on this issue at Github: https://github.com/xaviml/controllerx/issues/58
Anyway, the E1743 (square) and the E1810 (round 5 button) remote do not use same HA calls.
The E1810 uses HA ātoggleā call for on/off and the E1743 uses HA on/off calls.
And as latest ControllerX v2.4.3 uses transition with both on/off and toggle calls, it brings issues when turning on after off with a transition.
This is not a fault from ControllerX side, but a bug in the way the Zigbee converter acts. This issue has been solved in latest zigbee2mqtt-edge (dev.) version and will according to Koenkk be pushed with next ordinary z2m update in a week or two.
So, if I, Xavi or anyone else should be able to nail your specific issue, we need to know which zigbee2mqtt version yourāre on and which ControllerX version your using
It CAN work with Ikea bulbs on z2m - even when using transition attributes. For now, you need to ātweakā a bit, but when next z2m is released and Xavi has adapted ControllerX code a bit, then hopefully all HA calls, with or without transition, will work flawlessly from ControllerX
I have one Ikea White bulb only dimmable somewhere in the house
Iāll locate it and test this as well here with my setup. Iāve only tested 2 different types of WS Ikea bulbs and Ikeaās color bulb. All three had exact same behaviour/issues here.
Ciao !
Hiā sebul0n
Had to read your post several times before (I think) I understand your problem
Controllerx standard lightcontroller app fails to turn on light at previous brightness, but direct HA calls from custom controller works.
- Even if you have no transition period specified in app, it will send ādefaultā transition period from ControllerX code.
- Even if you specify transition: 0, ControllerX will still send the attribute.
I assume your on ControllerX v2.4.3 then and has āstableā z2m v1.12.0 installed ?
If yes, I believe your problem will be solved if you switch to edge version of z2m (developers version)
Alternatively, wait it out till next scheduled stable z2m release.
After that, only one issue left (I know off) with sync function from on position.
Ciao !
I switched to CallServiceController
already :-).
Thanks for help anyway
Be safe
Hi Xavi,
few days ago i installed a ControllerX and it is awesome! Thanks for your time spent on this project.
Although, i got a question.
I am using a deconz (conbee2) and i got E1810Controller (aka the puck) and i am trying to control two lamps with 1 puck - do you think it is possible? Like brightness up and down will turn on/off lamp1, arrow left and arrow right will turn on/off lamp2 and middle button will be called from customcontroller to turn off everything in house?
Thanks for replu.
Hi @slamkalukas,
Indeed, it is possible. Thanks to AppDaemon, you can create different app instances. In your case you will need 3 ControllerX app instances:
- One with CustomLightController to map on/off with brightness buttons lamp1
- One with CustomLightController to map on/off with arrow buttons lamp2
- Another one with either CustomLightController if what you want is turn off all lights with the center button or CallServiceController to turn off anything else.
I recently answer someone with similar needs that you have.
I hope this makes sense, if you have any problems, I can help you with the configuration
Hi @slamkalukas,
I happened to add in the examples of ControllerX documentation a configuration that matches what you want. It is not yet into the oficial doc, but it will be once I do the next release.
"Controlling different lights with the E1810 controller. Using brightness buttons for one light, arrows for another one and the center to turn off a group of lights.
light1_controller:
module: controllerx
class: CustomLightController
controller: e1810_controller
integration: deconz
light: light.light1
mapping:
2002: "on"
3002: "off"
2001: hold_brightness_up
2003: release
3001: hold_brightness_down
3003: release
light2_controller:
module: controllerx
integration: deconz
light: light.light2
mapping:
4002: "on"
5002: "off"
4001: hold_brightness_down
4003: release
5001: hold_brightness_up
5003: release
all_lights_controller:
module: controllerx
integration: deconz
light: group.all_lights
mapping:
1002: "off"
Thanks!
Thats exactly what i have done except all_lights_controller (i got also a wled led strip, so i am using an script for that).
One more question: for āonā function - is it possible to send also some data as well? My usecase is for remote which i got next to my bed and i usually use it only in the evening, so it would be nice if i can pass a brightness level as well. What do you think?
Hi @slamkalukas,
There is no way to send specific data to the āonā action in the CustomLightController. This Controller just allows to map button events to predefined actions. It has the advantage of using difficult actions such as hold_color_up
, but it does not allow to add data to those actions.
However, I created a CallServiceController
for this purpose, to customise the events with HA call services. This allows to bind button events to services + attributes. You can check the documentation about it in here and some examples in here.
Thank you for a really good app! Very useful and easy to get started with.
Something I would like to accomplish is that when I call a HOLD_BRIGHTNESS_UP and the light is off I would like the light to be turned on and then start to increase brightness(without first clicking the button and then clicking and holding).
I am pretty new to the whole object oriented python thing. But is wondering if you could guide me into the right direction to accomplish this?
Hi @karstensson,
Thank you for the appreciation and I am glad you find it useful.
What you are looking for is for an attribute from Light Controllers called smooth_power_on
. If you add this attribute and mark it to true
(itās false by default), then the light will turn on to minimum brightness when hold and clicked. However, you will need to hold again to start dimming up.
Summary, there is no way to start dimming up the light by just holding the button when the light is off, you will need to click or hold twice the brightness up button for that with the smooth_power_on
option.
This made me think that I could add a new option to the smooth_power_on
that would allow continuing dimming up the light when holding.
Actually, this was something which my friend mentioned yesterday! And maybe you can do also smooth_power_off? When i will be holding hold_brightness_down and i reach minimum brightness, after additional 1s it will turn off the lamp.
Thanks for the anser, Ill try smooth_power_on
Hi @htvekov
Thank you for your time. I agree with the āthe land of endless possibilitiesā!
Totally understand, that itās not an easy task to test and debug everything with all different bulbs and setups. I really do appreciate the work you had done, this have saved lots of hours and nerves of my life. I will consider checking the bug if have excess freetime
Sorry for the unclear description of my issue. Yes, you understood correctly the issue.
And you guessed the version numbers correctly, here they are:
zigbee2mqtt version: 1.12.0
ControllerX version: 2.4.3
I would say that no need to check the issue deeper. I got the working solution (in above post) by adding the mapping config (somehow it will work with it). And like you stated, I will wait the newer zigbe2mqtt and ControllerX and try then again.
Cheers!
Hi, I could not get āshakeā or āflip90ā or āflip180ā or āfallā work with the Xiaomi Cube, a light bulb and z2m. Tap works with ātoggle lightā, rotate left/right work with brightness_step_pct.
I also tried scenes or even scripts calling scenes but no success. Is there because of the cube default behaviour?
Using last versions of z2m and ControllerX / appdaemon addon (HA 107.7)
cube_bedroom:
module: controllerx
class: CallServiceController
controller: sensor.cube_chambre_martin_action
integration: z2m
mapping:
fall:
service: light.turn_on
entity_id: light.ampoule_martin_plafond_light
brightness_pct: 10
color_temp: white
flip90:
brightness_pct: 40
color_temp: orange
flip180:
brightness_pct: 100
color_temp: white
rotate_left:
brightness_step_pct: -25
rotate_right:
brightness_step_pct: +25
shake:
brightness_pct: 80
color_temp: red
slide:
brightness_pct: 80
color_temp: white
tap:
service: light.toggle
Any clue?
Hi htvekov and xaviml,
I take back what I said about the mapping ā It did worked for me few days back but somehow it does not work anymore.
I will wait the new versions of z2m and ControllerX.
However, I would like to understand how the mapping works. Can I use it for any service and for any buttons which are supported by controller?
Let say I have the following mapping:
module: controllerx
integration: z2m
light: light.MY_LIGHT1_light
mapping:
on:
entity_id: light.MY_LIGHT2_light
I assume that this would turn on my both lights 1 & 2 OR just my light 2, but in reality it only turned on my light 1.
Hi @dede34fr,
ControllerX just maps the state of the sensor with services, so I would try first if āflip90ā, āflip180ā and āfallā appear on z2m logs. If they do, then I would check to call the HA services through Developer Tools. If that also works then, you could check the logs for AppDaemon.
I do not see any mistakes in the configuration you sent.
Regards,
Xavi M.
