That would be a perfect Christmas gift. .-)
Hi Xavi,
thank you so much for your answer. I will try it and will report here if I had success!
Regards,
viertausend
Hola,
No soy capaz, cuan creo que tengo todo bien el mensaje que me sale del log de appdaemon es:
2020-12-09 18:03:10.048799 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
mi appdaemon.yaml es:
appdaemon:
latitude: XXXXXX
longitude: yyyyy
elevation: 80
time_zone: Europe/Madrid
threads: 10
plugins:
HASS:
type: hass
ha_url: 192.168.1.2:8123
token: eyJ0I0MjljYjU3NxxxxxxxxxxxxxxxxxxpL7jCBvmo
http:
url: http://192.168.1.2:5050
admin:
api:
hadashboard:
Gracias.
Hola @markina,
ĀæCĆ³mo has instalado AppDaemon? ĀæA travĆ©s del addon de la addon store?
Gracias,
Xavi M.
Hola Xavi,
Tengo el home assistant normal, pero ya lo resolvĆ, el problema era que tenia acceder por https ( Lets EnCrypt)
Muchas gracias
Hey, @allen024, it would be helpful if you described your solution, instead of just āFigured it out.ā It can help people who hasnāt figured it out yet. (Obligatory xkcd)
The āsolutionā I found was to create two apps for the same controller. One app uses the light class E1743Controller
, the other uses the switch class E1743SwitchController
. That way, the light class can behave as expected (including the hold action and all the customization parameters), while the switch class can disable the circadian switch (by setting its mapping
to 'off'
in reaction to the hold events).
I took me a while to figure out that I could create multiple apps listening to the same events from the same controller, as none of the many examples had that. (Well, at least the many examples I looked at.)
Hiā @chbndrhnns
Well, people like me probably struggled for countless of hours with hopeless, semi-working automations as the end resultā¦
ControllerX is absolutely brilliant and now Xavi has spent countless of hours for a year now - constantly improving on this fab little app
This app can now be tweaked in so many ways, that almost anything is possible with a zigbee controller.
Ciao !
Hello!
Would it be possible on a 5 buttons Ikea remote control to use the left and right buttons to change the light that is controlled?
(the question has probably been askedā¦).
Merci
Hi @Canaletto,
Someone asked recently this on the GitHub platform, you can read here. ControllerX does not natively support this, but it can be easily achieved with the help of an input_select
from HA + Callback constraints from AppDaemon.
Let me know if you have any questions.
Cheers,
Xavi M.
P.S.: I read your post from your blog about ControllerX. I had to translate it, but I liked it
I applied this example (modified for DeconZ) and it works well. But I still have some latency, I donāt know if it comes from ControlerX or DeconZ, I have to do the test with z2mqtt to seeā¦
Which sort of latency do you have? When dimming the brightness or when switching between lights with the arrows?
@denilsonsa Sorry for that. Here is the the automation I created which disables the Circadian Lighting custom component switch if I press any of the Ikea remote buttons except the middle one. Just change āikea_5bremote1ā with the id of your remote.
automations.yaml
- id: '1601143465533'
alias: Turn Off CL Switch
description: Disable CL when brightness or color temp is manually adjusted
- platform: event
event_type: deconz_event
event_data:
condition:
- condition: state
entity_id: switch.circadian_lighting_circadian_lighting
state: 'on'
- condition: and
conditions:
- condition: template
value_template: '{{ trigger.event.data.event in [2002, 2001, 2003, 3002, 3001,
3003, 4002, 5002] }}'
- service: switch.turn_off
data: {}
mode: single
Also updated my āFigured it out.ā post with this.
Hello Xavi and the rest
I am having a problem with trying multiple clicks:
controller itself works fine, just no multiple click is exectued:
chodba_xiaomi_controller:
module: controllerx
class: E1743Controller
controller: tradfri_switch_2
integration: deconz
light: light.chodba
smooth_power_on: true
multiple_click_delay: 500
merge_mapping:
1002$2: on_min_color_temp
1002$3: set_half_color_temp
1002$4: on_full_color_temp
do you see any issue with config? Thanks.
Hi @slamkalukas,
I do not see anything out of place with this configuration. Could you please share your AppDaemon logs when initializing the controller (the section where the ControllerX version appears) and when double clicking as well?
Regards,
Xavi M.
Hi Xavi,
sure, here is the log:
2020-12-26 13:51:13.754661 INFO AppDaemon: Initializing app chodba_controller using class Controller from module controllerx
2020-12-26 13:51:14.131288 INFO nika_ikea_controller: š® ControllerX v4.3.0
2020-12-26 13:51:14.157299 INFO nika_xiaomi_controller: š® ControllerX v4.3.0
2020-12-26 13:51:14.167232 INFO lukas_xiaomi_controller: š® ControllerX v4.3.0
2020-12-26 13:51:14.179500 INFO chodba_ikea_controller: š® ControllerX v4.3.0
2020-12-26 13:51:14.190989 INFO chodba_controller: š® ControllerX v4.3.0
2020-12-26 13:51:14.197836 INFO AppDaemon: App initialization complete
No errors. It seems to me that ControllerX is not waiting X miliseconds - when i press 1002, the action is executed immediately.
I also tried another approach - check the config below:
module: controllerx
class: LightController
integration: deconz
light: light.chodba
multiple_click_delay: 1000
mapping:
1001: hold_brightness_up
1002: "on"
1003: release
2001: hold_brightness_down
2002: "off"
2003: release
And this is working as expected - single clicks and multiclicks as well.
Any ideas why merge_mapping is not working as expexted?
Thanks.
Lukas
I trying to setup custom mapping with an Ikea E1743 dimmer. This is what I have and have tried several combination, but the on
and off
mapping does not trigger. However, the last 2 triggers. I have tested the top 2 service in developer tool and they both triggers.
computer_room_curtains:
module: controllerx
class: Controller
controller: sensor.cr_curtains_action
integration: z2m
mapping:
on:
service: cover.open_cover
entity_id: cover.computer_room_curtains
off:
service: cover.close_cover
brightness_move_up:
entity_id: cover.all_curtains
brightness_move_down:
Update: Got it working now. Strange, I have seen this page (last section) and tried the sample code but it didnāt work. Tried again and it works now. I might of added the wrong class
. Cool beans.
module: controllerx
class: E1743SwitchController
integration: z2m
switch: switch.computer_room_curtains
merge_mapping:
brightness_move_up:
Hi All,
Iām probably being stupid here but I need some helpā¦ I have a Sonos speaker which I am controlling with a E1810MediaPlayerConroller, but I cant get it to scroll through the radio stations I have set on itā¦ the left and right buttons do nothingā¦ now I know it is something I have done or am not doing but Ihave no idea what that isā¦
here is what I have in apps.yaml
sonos_controller:
module: controllerx
class: E1810MediaPlayerController
controller: sonos_controller
integration: deconz
media_player: media_player.sonos
if I go into āstatesā I have the following
source_list:
- Absolute Classic Rock
- BBC Radio 1
- Nation Radio Scotland
- Pure Radio Scotland
volume_level: 0.06
is_volume_muted: false
media_content_id: 'x-rincon-mp3radio://https://listen-pureradio.sharp-stream.com/pure_radio.mp3'
media_content_type: music
media_title: Pure Radio Scotland
media_channel: Pure Radio Scotland
source: Pure Radio Scotland
shuffle: false
repeat: 'off'
sonos_group:
- media_player.sonos
friendly_name: Sonos
supported_features: 457279
can anyone help me?
Hiā @Rdoull
Iām using z2m integration, but it should work anyway.
Just remember that default mapping is hold
action for scrolling back/forth in your Sonos source list. Click
action is for next/previous track in playlists.
Iāve flipped this behaviour in my setup, as I mainly use the remote when playing radio stations.
Example below you can find here among the other ControllerX examples.
sonos_speaker:
module: controllerx
class: MediaPlayerController
controller: sensor.0x90fd9ffffe0cbd69_action
integration: z2m
media_player: group.sonos_all
mapping:
toggle: play_pause
brightness_up_click: click_volume_up
brightness_down_click: click_volume_down
brightness_up_hold: hold_volume_up
brightness_down_hold: hold_volume_down
brightness_up_release: release
brightness_down_release: release
arrow_right_click: next_source
arrow_left_click: previous_source
arrow_right_hold: next_track
arrow_left_hold: previous_track
Ciao !
Hi, I have overhead lights and was able to connect my Ikea tradfri remote to Home Assistant via ZHA. In my bedroom, I have an Aqara Zigbee plug to repeat signals. I was able to identify button pushes for the remote (see log below), but, for whatever reason, anytime I push the on/off button on the trader remote, it turns on/off my Zigbee plug (and the lights) rather than just the lights. Any help appreciated, I am using the device ID from the remote as far as Iām aware. Thank you
Additional information
- Devices involved:
- Model: IKEA E1810 as Controller
- Integration: zha
- AppDaemon version: 4
- ControllerX version: latest via HACS
- HACS version (if installed from there): latest
- Home Assistant Core version: latest
AppDaemon app configuration
bedroom_controller: module: controllerx class: E1810Controller controller: XXXX integration: zha light: light.master_bedroom_lamps actions: - āonā - āoffā
Logs
"event_type": "zha_event",
"data": {
"device_ieee": "XXXX",
"unique_id": "XXXX:1:0x0008",
"device_id": "_long-id-number_",
"endpoint_id": 1,
"cluster_id": 8,
"command": "step",
"args": [
1,
43,
5
"origin": "LOCAL",
"time_fired": "2020-12-26T23:10:39.059636+00:00",
"context": {
"id": "_long-id-number_",
"parent_id": null,
"user_id": null
Have an Ikea sound controllers E1744 however the jumps in volume for Sonos app are to large i.e. 1/4 of a turn on the controller equals an 80% increase in volume. Any way to increase the turns needed? for example 2 full rotations equal 100% volume increase.
apps.yaml
tv_sonos_speaker:
module: controllerx
class: E1744MediaPlayerController
controller: sensor.sound_controller_action
integration: z2m
media_player: media_player.living_room
Configuration.yaml
'0x14b457fffe663c57':
friendly_name: sound_controller
legacy: false
