Hi @allen024,
Yes, that is correct. In fact, instead of “colortemp”, you can just use “color”. It will use color temperature of xy color depending on the light you have automatically.
Regards,
Xavi M.
Hi @allen024,
Regards,
Xavi M.
Hi Xavi, thank you for creating this app. It looks very promising.
I have one of these zigbee RGB Genie controllers now and would like to work with you to set it up. I just had this model added to the zigbee2mqtt project
Below are all of the states from pressing and holding the buttons. Manual for your reference, although this one doesn’t explain the button presses in full.
on/off
Zigbee2MQTT:info 2021-01-27 14:39:09: MQTT publish: topic 'zigbee2mqtt/0x000d6f0014cbe75d', payload '{"action":"off","linkquality":123}
Zigbee2MQTT:info 2021-01-27 14:39:09: MQTT publish: topic 'zigbee2mqtt/0x000d6f0014cbe75d', payload '{"action":"on","linkquality":123}
scene 1, 2, 3
Zigbee2MQTT:info 2021-01-27 15:35:26: MQTT publish: topic 'zigbee2mqtt/0x000d6f0014cbe75d', payload '{"action":"recall_1","action_group":22785,"linkquality":125}'
Zigbee2MQTT:info 2021-01-27 15:35:26: MQTT publish: topic 'zigbee2mqtt/0x000d6f0014cbe75d', payload '{"action":"recall_2","action_group":22785,"linkquality":125}'
Zigbee2MQTT:info 2021-01-27 15:35:26: MQTT publish: topic 'zigbee2mqtt/0x000d6f0014cbe75d', payload '{"action":"recall_3","action_group":22785,"linkquality":125}'
red (add or remove red channel)
Zigbee2MQTT:info 2021-01-27 16:21:53: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"color_move","action_color":{"x":0.734,"y":0.265},"action_group":22785,"action_transition_time":0,"linkquality":126}'
blue (add or remove blue channel)
Zigbee2MQTT:info 2021-01-27 16:21:55: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"color_move","action_color":{"x":0.166,"y":0.009},"action_group":22785,"action_transition_time":0,"linkquality":126}'
green (add or remove green channel)
Zigbee2MQTT:info 2021-01-27 16:21:58: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"color_move","action_color":{"x":0.273,"y":0.717},"action_group":22785,"action_transition_time":0,"linkquality":126}'
three rings (toggle through white warmth)
Zigbee2MQTT:info 2021-01-27 16:24:46: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"color_move","action_color":{"x":0.486,"y":0.425},"action_group":22785,"action_transition_time":0,"linkquality":126}'
brightness button (hold - down action)
Zigbee2MQTT:info 2021-01-27 16:25:41: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"brightness_move_down","action_group":22785,"action_rate":50,"linkquality":126}'
brightness button (hold - stop action)
Zigbee2MQTT:info 2021-01-27 16:25:42: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"brightness_stop","action_group":22785,"linkquality":126}'
brightness button (hold - up action)
Zigbee2MQTT:info 2021-01-27 16:26:02: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"brightness_move_up","action_group":22785,"action_rate":50,"linkquality":126}'
Play/pause button (for presets)
Zigbee2MQTT:info 2021-01-27 16:26:18: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"hue_move","action_group":22785,"linkquality":126}'
hold play button
max
Zigbee2MQTT:debug 2021-01-27 16:33:47: Received Zigbee message from 'RGBWallPanel_Basment_Bedroom', type 'commandMoveHue', cluster 'lightingColorCtrl', data '{"movemode":1,"rate":85}' from endpoint 1 with groupID 22785
min
Zigbee2MQTT:debug 2021-01-27 16:33:02: Received Zigbee message from 'RGBWallPanel_Basment_Bedroom', type 'commandMoveHue', cluster 'lightingColorCtrl', data '{"movemode":1,"rate":2}' from endpoint 1 with groupID 22785
pressing white circle
Zigbee2MQTT:info 2021-01-27 16:36:33: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"color_temperature_move","action_color_temperature":304,"action_group":22785,"action_transition_time":0,"linkquality":127}'
Zigbee2MQTT:info 2021-01-27 16:36:35: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"color_temperature_move","action_color_temperature":450,"action_group":22785,"action_transition_time":0,"linkquality":127}'
Zigbee2MQTT:info 2021-01-27 16:36:38: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"color_temperature_move","action_color_temperature":155,"action_group":22785,"action_transition_time":0,"linkquality":127}'
holding white circle (no release stop)
Zigbee2MQTT:info 2021-01-30 15:06:13: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"color_temperature_move_down","action_group":22785,"action_maximum":450,"action_minimum":155,"action_rate":60,"linkquality":209}'
Zigbee2MQTT:info 2021-01-30 15:06:13: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"","linkquality":209}'
Zigbee2MQTT:info 2021-01-30 15:06:13: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom/action', payload 'color_temperature_move_down
Zigbee2MQTT:info 2021-01-30 15:06:22: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"color_temperature_move_up","action_group":22785,"action_maximum":450,"action_minimum":155,"action_rate":60,"linkquality":209}'
Zigbee2MQTT:info 2021-01-30 15:06:22: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"","linkquality":209}'
Zigbee2MQTT:info 2021-01-30 15:06:22: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom/action', payload 'color_temperature_move_up'
color wheel
Zigbee2MQTT:info 2021-01-27 16:39:55: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"color_move","action_color":{"x":0.28,"y":0.06},"action_group":22785,"action_transition_time":0,"linkquality":127}'
Zigbee2MQTT:info 2021-01-27 16:39:55: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"color_move","action_color":{"x":0.28,"y":0.06},"action_group":22785,"action_transition_time":8,"linkquality":127}'
Zigbee2MQTT:info 2021-01-27 16:39:51: MQTT publish: topic 'zigbee2mqtt/RGBWallPanel_Basment_Bedroom', payload '{"action":"color_move","action_color":{"x":0.169,"y":0.029},"action_group":22785,"action_transition_time":8,"linkquality":127}'
I plan to use this with a WLED light
Hi @germplan,
I created this ticket in GitHub to add this controller. We can comment further in there about the controller.
Thank you for the detailed information of the events
Regards,
Xavi M.
Hi @xaviml
I’m thinking about my covers and the controllerx setup.
I would like to use the constrain possibility (constrain_input_boolean) on my window, so that if it is open, I can not make the cover close (it will crash the cover as the windows open inwards).
But can I only use the constrain on the entire controller app, or can I use it on a single action somehow.
I guess I could make seperate apps for up/down if it is only for the entire app, right?
Hi @fribse,
You’re correct, it only works for the whole config, so you’d need to create a separate config for that action with a constrain_input_boolean.
Regards,
Xavi M.
Note: Remember to restart the AppDaemon addon/server after updating to a new version.
mode
parameter to define what to do when an action is already executing. Similar to Home Assistant Automation modes. [ #242 ]xycolor_from_controller
and colortemp_from_controller
for light controllers. It allows to get color values from the controller event. [ #236 ]color_wheel
and color_temp
for MLI404011LightController with the new predefined actions xycolor_from_controller
.mute
predefined action for Media Player controllers [ #238 ]action_delay
and action_delta
z2m
integrationNow the Ikea TRÅDFRI Shortcut button is available online here in Germany: https://www.ikea.com/de/de/p/tradfri-shortcut-button-weiss-40356381/
Very nice update! Happy to have templating. Endless customizations. Very good template example too ;]
Thanks for the update @carsten_h. I see that Zigbee2MQTT documentation states that these are the possible values: on
, brightness_move_up
, brightness_stop
. I will add the device for next release.
Thanks! I did add another example in the Examples page. I leave it here for anyone interested on something similar:
The following example shows the potential of templating render. Let’s say we want to execute different predefined actions every time we click a button (E1810 in this case). First, we can create an input select through UI or YAML in HA:
input_select:
light_state:
options:
- on_min_brightness
- on_full_brightness
- set_half_brightness
Then we can define the following ControllerX config to change the option of the input_select and apply the predefined action that is selected:
example_app:
module: controllerx
class: E1810Controller
controller: livingroom_controller
integration:
listen_to: mqtt
light: light.my_light
mapping:
toggle:
- service: input_select.select_next
entity_id: input_select.light_state
- action: "{{ states('input_select.light_state') }}"
Great use of templates! Is it possible to call different scenes with one template?
My problem is the multiple_click_delay when using multiple clicks normally. The time 500ms is too short for me and my family to find the right scene.But a longer time is not usable because the scene does not appear fast enough.
The way about a template sounds good, but the best way would be to call different scenes with multiple clicks.
Hi @herrfelix,
I am not sure if I am following you. Do you want that everytime you click, it changes scene? For this you would not need multiple click, but you could do it with template. If this is what you want, I can quickly show you how. Otherwise, could you specify in much more detail what is that you want to achieve or what your problem is?
Thanks,
Xavi M.
Yes, each click a new scene.
Sorry for my ambiguity! I appreciate a tip with the templates.
Hi @herrfelix,
If I were to do this, I would first create an input_select like the following:
input_select:
scenes:
options:
- scene.my_scene_1
- scene.my_scene_2
- scene.my_scene_3
Then I would create the following ControllerX config:
example_app:
module: controllerx
class: Controller
controller: sensor.my_controller_action
integration: z2m
mapping:
toggle:
entity_id: input_select.scenes
- scene: "{{ states('input_select.scenes') }}"
Note that this would only change the scene when pressing the button (the toggle action in this case), if you are interested to change the scene when changing the input_select from Lovelace, then you will need a Home Assistant automation for it.
I did not try this, but it is very similar to the example I posted earlier, but with scenes.
Regards,
Xavi M.
Has something changed with the Hue Dimmer integration in the last few updates?
All has been perfect for the several months but now my Hue Dimmers have stopped working with no changes to any config bar a few software updates. They broadcast their events to ZHA as expected but nothing shows in the AppDaemon log other than the following example for each remote when restarting it…
2021-02-14 14:08:07.126706 INFO sams_wall_remote: 🎮 ControllerX v4.6.0
The Lightfy and Xiaomi controllers still work perfectly which implies something has only changed in the Hue function within ControllerX. Example config…
sams_wall_remote:
module: controllerx
class: HueDimmerController
controller: 00:17:88:01:02:d5:c9:65
integration: zha
light: light.sams_bedroom
manual_steps: 5
color_wheel:
- [0.701, 0.299]
- [0.172, 0.747]
- [0.136, 0.040]
- [0.477, 0.196]
merge_mapping:
on_short_release:
- service: scene.turn_on
entity_id: scene.sam_dim
on_short_release$2:
- service: light.turn_on
entity_id: light.ice_block
on_short_release$3:
entity_id: light.sams_bed
off_short_release$2:
- service: light.turn_off
off_short_release$3:
on_short_release$4:
entity_id: scene.sam_morning
off_hold:
entity_id: light.sams_spots
zha_event from a single press of the ‘on’ button…
"event_type": "zha_event",
"data": {
"device_ieee": "00:17:88:01:02:d5:c9:65",
"unique_id": "00:17:88:01:02:d5:c9:65:1:0x0006",
"device_id": "a4ccc4e707ed11eb98bbb996b550e78a",
"endpoint_id": 1,
"cluster_id": 6,
"command": "on",
"args": []
"origin": "LOCAL",
"time_fired": "2021-02-14T15:13:08.041689+00:00",
"context": {
"id": "98837b7205cf3c0accb4c0d3db233e76",
"parent_id": null,
"user_id": null
The IEEE still matches what’s seen in ZHA and no faults show in any log so scratching my head now.
Hi Xavi,
Thank you for the great integration. I had it working with ZHA and now moving to z2m, still working great.
What I am wondering, can I use the controllerx without using HomeAssistant at all?
So I want the controller (to listen to) from zigbee2mqtt and the light receiving the signal from controllerx using mqtt.
This would be nice, because when HA is unavailable (for example due to a restart), the light still work.
Thanks for your reply!
Kind regard,
Daniel
I think the multiple clicks idea is great. Unfortunately, my wife does not get along with it.
We had previously used the Hue dimmer switches and configured the assignment of the buttons via iConnectHue. Since it ran so:
The time between the clicks could be up to ten seconds before it started again from the beginning. This allowed each scene to be viewed before the next one was selected.
In your implementation, I need to know in advance how many times I need to press the ON button to select a particular scene. And that within 500ms.
Do you understand what I mean? Is there any way to implement my desired behavior? That would be fantastic!
Hi @herrfelix
That is not true, in the implementation I showed you last, you can wait as much time as you want between each click. It does not leverage the multiclick feature. So every time you press the button, it will:
Have you tried the configuration? Did you run to any problems? Happy to help further
Regards,
Xavi M.
Hi @Bobby_Nobble,
Could it be that you changed the firmware of your controller recently? The “on” event does not match with the current mapping for this controller with ZHA.
I would say the problem is that you are running an old firmware for this controller. Someone raised this same concern in GitHub. In that ticket I left a configuration with the old mapping if you are not willing to upgrade the firmware, but as I said in the ticket ControllerX just mantains up-to-date mappings.
Hope this helps, and sorry for the inconvenience
Regards,
Xavi M.
Yes, I have tried that and it works wonderfully. In practice, however, it is not quite as practical for us. To stay with my example:
In the evening I turn on Scene B with two clicks. Then I turn off the light and turn it on again the next day. Then it starts not with Scene A but with Scene C. This confuses my roommates here :).
Maybe it’s a luxury problem, but my wife is annoyed by it
