So this has exactly the same functions as the E1810? No change, only another look?
If I find the time and Ikea is open I will look for one at the end of the month.
Yes, it is almost the same button but without a middle button, so it only has 4 buttons, not 5. The top button click is used as a toggle, but the rest works the same as the E1810 in ControllerX. These are the advantages and disadvantages I see for this controller:
Advantages:
It looks nicer than E1810
It has less 1 button and you can stilll do practically the same
Disadvantages:
The experience is less pleasant than the E1810 since it is bigger and more difficult to manage
It works with AA batteries which for me is a disadvantage. The E1810 works with button battery and it already lasts a lot.
This is my opinion, someone might think different.
Before HA 2021.5 it was possible to control the colour with ControllerX. With 2021.5 the colour-wheel in HA was not working. You selected a colour and the light switches back to white. Then I installed the tasmota integration and the colour wheel in HA is working again.
The error is in the tasmota integration since it indicates that the light only supports effect and transition. I know this because of the supported_feature attribute (36), which is a flagged variable. The working light is 63, which indicated support for brightness, color_temp, effect, transition, flash and color. This supported_feature is important for controllerx to know which which color attribute to use (color_temp or xy_color). It is also used to check if an action should be called or not depending on the supported feature from the entity.
ControllerX does not have a mechanism to ignore the supported feature, since this is not a common use case (it is a bug on the integration), however, it would be a good idea to add such functionality to make ControllerX believe everything is supoprted, and if needed it can fail. For this I created the following ticket: Add a new attribute to ignore `supported_features` attribute · Issue #314 · xaviml/controllerx · GitHub
However, since I might take a while to develop this, there is a workaround for you that would be more elegant than even having the feature I just mentioned. The Light Controller has an attribute called color_mode inside the light mapping to indicate which type of color you want to use for the light. By default is auto and it detects (through supported_features) if the light uses xy_color or color_temp. The color_mode is handy if light uses both and you want to use one in specific. However, this attribute is also in your favour since if you select xy_color, it will avoid checking the supported_features.
TL;DR: This is the proposed configuration to solved the problem.
This should do the trick and work without errors. You can also use color_temp for the color_mode if you want the color temperature to work instead of xy color. Hope it helps
There is no click up for brightness since it does toggle, but you can hold the button for brightness up. Again, for me it is neither an advantage nor a disadvantage since I barely use the click up brightness. I either do double click for brightness up (custom config) or hold the button.
That is true, AA batteries are easier to find. I have not had the controller long enough to report on battery status, but I am guessing it should last quite a lot as well.
Yes, this works without any problem. Thank you very much!
Ok. Then it seems for an media player it is not the correct remote. I think I will stay with the E1810. They work great. For media player I am using the E1744 which is really great with ControllerX!
I have issue with smoothness.
Brightness up and down is not smooth at all. It looks like is jumping up around 10%.
I have tried Ikea multicolor bulb, Ikea driver (connected to Ikea hub) and also sonoff multicolor bulb (connected to eWeeLink). Ikea switch connected by ZHA. I am using dongle CC2531.
I would say this is a network problem. Not sure 100% about IKEA hub, but the Eweelink goes through the internet to make changes to your devices, so it connection is not locally. This means that ControllerX together with Home Assistant is sending more requests than the light can handle. It probbaly happens the same with the IKEA hub.
First, I recommend you to play around with delay (default is 350ms) and automatic_steps (default is 10) attributes. You can read more about them in here . The higher the delay is, the less request will be make to HA. The more automatic_steps, the more steps it will take to get from min to max and vice versa. Maybe you can find the right setting for both atrributes that satisfy your needs.
However, what I really recommend you is that you integrate those lights with ZHA or any other local integration. Not sure about the sonoff light, but you can definetely integrate the IKEA light with ZHA. The smoothness issues will disappear since the network will be able to respond immedeately.
Thank you for quick response.
I think as well that is network problem.
I want to move all ikea devices to my new zigbee dongle anyway. I will post back if that helped. Sonoff bulb is wifi so can not to be added.
Indeed. I also realised that the original behaviour for this controller is to turn on by pressing the brightness up, and turn off with brightness off. And this is the default mapping is implemented in ControllerX. I thought (and I told you before) the brightness up would toggle the light, but to do that the default mapping needs to be changed throught configuration.
I have integrated ikea bulb with ZHA and transition is smooth now, but I noticed there is no transition when bulb is off and I press ON button. Bulb is going straight to last brightness without transition.
This is really weird.
I installed AppDaemon 4 and ControllerX, restarted the server and I don’t see the up_press 1002 and down_press 2002 anymore when running deconz_event.
Before, when trying to control the light via Automation I was able to see the 1002 and 2002. Any idea what this can be?
What do you mind you don’t see it? Do you mean that you don’t see the event when listening to deconz_event in the Developer Tools? If that is the case I can assure you that AppDaemon and ControllerX does not have anything to do with that, they run different in a different process from deconz. If the events are not popping up, I would recommend you to take a look to the deCONZ integration and see if it is working as expected. If you don’t see anything, I would recommend you ten to restart Home Assistant, sometimes a good restart fixes the weirdest things…
In fact, those events are important because ControllerX listens to those events from Home Assistant to make the controllers work.
I don’t use deCONZ as a main integration, but I do have it for testing purposes, so I can help you further debug this problem if you specify with the details.
I have the same behaviour on Home Assistant as well. The transition is there but very fast. Only if brightness is low transition is visible and is ok. The same behaviour is on zha and z2m. All is good when bulb is connected to IKEA hub and hub to HA through IKEA integration. I will try different IKEA bulb. Log looks fine to me.
