You are correct. ControllerX does not turn on the light when brighting up/down. There is no option to directly do that, but it is not a but idea. However, I am not saying is impossible to achieve, it is just verbose. The configuration for the left dimmer would be:
So, you just need to add āonā to all actions. The actions is no needed anymore because mapping is used.
I would suggest using action_delta as well, but I would use something larger than 300 (the default), so it would send a request every X milliseconds, whatever you put in action_delta.
Thanks for the update, and your HUGE work !
Can I check if the ādouble clickā is seen, because now it looks like itās not seen, double click is seen as single click :
Not sure how fast you are double-clicking, but I see you are using the regular z2m integration. This listens to state changes, so there might be delays. There are 2 options for you to try:
Increment the multiple_click_delay variable to 800 or higher and do much slower double clicks.
Switch to MQTT listener for the z2m integration. This will allow ControllerX to listen to MQTT messages directly and not need to listen to state changes from HA. You can read more about this here.
I will try this later on, for now, itās working 95% of the times, so OK for me.
I also have another question, I have also some spare ā E1743 (IKEA)ā switches.
I would like to use one as an āauto fade-in, fade-outā button.
So, when I press the ON button, the light starts at 1% brightness and goes to 100% in 10 minutes.
Also, the other way around, when I press the OFF button, I would like the light to go from current brightness to off in about 10 minutes. Is this possible within ControllerX, or do I need to do this with automation or node-red ?
I can get the HUE Dimmer - Philips929002398602LightController into DeConz but it seems not to be supported in ControllerX with DeConz.
Is there any chance this will be supportet in the future ?
Apps log:
2022-02-26 17:40:50.675612 INFO AppDaemon: Initializing app dimmer_bryggers_X2 using class Philips929002398602LightController from module controllerx
2022-02-26 17:40:50.691410 INFO dimmer_bryggers_X2: š® ControllerX v4.18.2
2022-02-26 17:40:50.708153 WARNING dimmer_bryggers_X2: ------------------------------------------------------------
2022-02-26 17:40:50.709279 WARNING dimmer_bryggers_X2: Unexpected error running initialize() for dimmer_bryggers_X2
2022-02-26 17:40:50.710329 WARNING dimmer_bryggers_X2: ------------------------------------------------------------
2022-02-26 17:40:50.711883 WARNING dimmer_bryggers_X2: Traceback (most recent call last):
File "/usr/lib/python3.9/site-packages/appdaemon/app_management.py", line 163, in initialize_app
await init()
File "/config/appdaemon/apps/controllerx/cx_core/controller.py", line 108, in initialize
await self.init()
File "/config/appdaemon/apps/controllerx/cx_core/type/light_controller.py", line 147, in init
await super().init()
File "/config/appdaemon/apps/controllerx/cx_core/type_controller.py", line 63, in init
File "/config/appdaemon/apps/controllerx/cx_core/release_hold_controller.py", line 18, in init
File "/config/appdaemon/apps/controllerx/cx_core/controller.py", line 121, in init
default_actions_mapping = self.get_default_actions_mapping(self.integration)
File "/config/appdaemon/apps/controllerx/cx_core/controller.py", line 239, in get_default_actions_mapping
raise ValueError(f"This controller does not support {integration.name}.")
ValueError: This controller does not support deconz.
2022-02-26 17:40:50.712964 WARNING dimmer_bryggers_X2: ------------------------------------------------------------
Iām having major difficulties getting this up and running. Iāve installed the ControllerX through HACS. I couldnāt find it initially but it showed up under automations at some point. However I cannot for the life of me get it to work.
I have a config/appdaemon/apps/apps.yaml file that I put my configuration for the remote in, but thereās no config/appdaemon/appdaemon.yaml, and I donāt know where thatās supposed to come from.
You link to the hassio install instructions mentions the "AppDaemon 4" add-on in the Supervisor add-on store but it is not there. So far I have not been able to figure out how I am supposed to get this working. Any ideas?
I have never tried this with ControllerX, and I never included this as a use case since the idea is that ControllerX allows you interact āimmidiatelyā between controllers and devices. However, this is possible by tinkering some delays. For this, you can leverage the hold action and tweak delay and automatic_steps. You can read more about those parameters here: Controller types - ControllerX
This is a rough example of what you would like to achieve:
example_app:
module: controllerx
class: E1743Controller
controller: sensor.livingroom_controller_action
integration: z2m
light: light.bedroom
automatic_steps: 20 # This indicates how many times we change the
delay: 30000 # 600000ms (10 minutes) divided by 20 (automatic_steps)
merge_mapping:
"on": # When "on" button is pressed ...
- on_min_brightness # ... we first change brightness to minimum
- hold_brightness_up # ... we start changing the brightness
When you press the āonā button, it will change brightness to 1% and start changing the brightness towards 100% every 30 seconds (20 times, which is 10 minutes).
Controllers are supported when the default mapping is defined. In this case, I would need to know from someone with this controller the events of the controller. For this, you will need to fill in this ticket form.
Even if the controller is not added, you can use the standard LightController and define the mapping with the mapping attribute. You can read more about custom mapping here.
ControllerX runs on AppDaemon, which can be executed with the AppDaemon addon from the addon store. They have recently renamed the addon from AppDaemon 4 to just AppDaemon.
This controller does not have yet a default mapping for Z2M integration. This is because I do not have this controller, so I do not know what are the events that fired. However, adding support to it is quite strainght forward, but not possible if the mapping is not known. Could you please fill the āNew Deviceā form when creating an issue in the GitHub repository? You will need to share in the the events that the device fires.
Hey @xaviml ! Thanks for this awesome solution.
For several days i was trying to make the Hue Dimmer Controller working with Z2M.
Iām using a seperate RPI which runs Z2M but it did not work at all.
Turns out i canāt use the class HueDimmerController but need to use
Philips929002398602LightController. Really strange because it is the same Controller as in the picture .
Maybe itās my config but i thought it was worth mentioning for other users encountering the same issue.
Note that there are 2 Hue Dimmer controllers which are very similar. If you have the one on that picture, it means that you should be using class: HueDimmerController. Could you please share your exact configuration and the AppDaemon logs when it initializes and when you interact with the controller?
