I can see the dimming function inside z2m
Totally new to ControllerX and AppDaemon hereâŠ
The user and password that need to go into appdaemon.yaml, I donât know what user this is supposed to be. Iâve checked my mqtt broker and I havent created any specific users and inly rely on the HA users. Do I have to create a new user (here), and are there any unforseen consequences of doing this?
Hi @xaviml ,
I finally found some time to test this. Unfortunately the default mapping is not working. Only the âonâ and âoffâ is working.
When i hold the buttom down i see the event in de AppDeamon log but comes with a lot of errors and nothing happend after that.
I have a led strip with the Wled integration.
Here is my Config:
LedstripLogeerkamer:
module: controllerx
class: E2002LightController
integration: deconz
controller: led_strip
light: light.led_logeerkamer
Here is the outcome when i hold the button_down:
2023-03-02 16:40:01.764582 INFO LedstripLogeerkamer: đź Button event triggered: `2001`
2023-03-02 16:40:01.766958 INFO LedstripLogeerkamer: đ Running `Predefined (hold_brightness_down)` now
2023-03-02 16:40:01.770620 WARNING LedstripLogeerkamer: ------------------------------------------------------------
2023-03-02 16:40:01.770920 WARNING LedstripLogeerkamer: Unexpected error in worker for App LedstripLogeerkamer:
2023-03-02 16:40:01.771178 WARNING LedstripLogeerkamer: Worker Ags: {'id': '6644abbb7c6e48f2931bd844ad6b8e3b', 'name': 'LedstripLogeerkamer', 'objectid': 'd3118ec227b748aeb14cf3d667b47c5a', 'type': 'event', 'event': 'deconz_event', 'function': <bound method DeCONZIntegration.event_callback of <cx_core.integration.deconz.DeCONZIntegration object at 0x7fce6d206b90>>, 'data': {'id': 'led_strip', 'unique_id': '94:de:b8:ff:fe:07:92:45', 'event': 2001, 'device_id': 'd36115c4a9ac0c87a4c309494f5a823a', 'metadata': {'origin': 'LOCAL', 'time_fired': '2023-03-02T15:40:01.760732+00:00', 'context': {'id': '01GTHFNXV0RW0W0RG22Y1STZDQ', 'parent_id': None, 'user_id': None}}}, 'pin_app': True, 'pin_thread': 2, 'kwargs': {'id': 'led_strip', '__thread_id': 'MainThread'}}
2023-03-02 16:40:01.771433 WARNING LedstripLogeerkamer: ------------------------------------------------------------
2023-03-02 16:40:01.771844 WARNING LedstripLogeerkamer: Traceback (most recent call last):
File "/usr/lib/python3.10/site-packages/appdaemon/threading.py", line 855, in async_worker
await funcref(args["event"], data, self.AD.events.sanitize_event_kwargs(app, args["kwargs"]))
File "/config/appdaemon/apps/controllerx/cx_core/integration/deconz.py", line 34, in event_callback
await self.controller.handle_action(data[type_], extra=data)
File "/config/appdaemon/apps/controllerx/cx_core/controller.py", line 404, in handle_action
await self.call_action(action_key, extra=extra)
File "/config/appdaemon/apps/controllerx/cx_core/controller.py", line 478, in call_action
await self.action_timer_callback({"action_key": action_key, "extra": extra})
File "/config/appdaemon/apps/controllerx/cx_core/controller.py", line 516, in action_timer_callback
await task
File "/config/appdaemon/apps/controllerx/cx_core/controller.py", line 532, in call_action_types
await action_type.run(extra=extra)
File "/config/appdaemon/apps/controllerx/cx_core/action_type/predefined_action_type.py", line 118, in run
await action(*positional, **action_args)
File "/config/appdaemon/apps/controllerx/cx_core/controller.py", line 60, in _action_impl
continue_call = await controller.before_action(method.__name__, *args, **kwargs)
File "/config/appdaemon/apps/controllerx/cx_core/type/light_controller.py", line 799, in before_action
self.remove_transition_check = await self.check_remove_transition(
File "/config/appdaemon/apps/controllerx/cx_core/type/light_controller.py", line 438, in check_remove_transition
or await self.feature_support.not_supported(LightSupport.TRANSITION)
File "/config/appdaemon/apps/controllerx/cx_core/feature_support/__init__.py", line 41, in not_supported
return not await self.is_supported(feature)
File "/config/appdaemon/apps/controllerx/cx_core/feature_support/__init__.py", line 38, in is_supported
return feature & await self.supported_features != 0
File "/config/appdaemon/apps/controllerx/cx_core/feature_support/__init__.py", line 32, in supported_features
raise ValueError(
ValueError: `supported_features` could not be read from `light.led_logeerkamer`. Entity might not be available.
2023-03-02 16:40:01.772110 WARNING LedstripLogeerkamer: ------------------------------------------------------------
2023-03-02 16:40:03.349568 INFO LedstripLogeerkamer: đź Button event triggered: `2003`
2023-03-02 16:40:03.352588 INFO LedstripLogeerkamer: đ Running `Predefined (release)` now
Can you tell me what iâm doing wrong?
EDIT: for some reason after the WLED was Powerd off for some time and offline. After 1 dat i put It back on and looks like Its working now.
Still have to test the FX part.
Has anyone here successfully setup ControllerX with the Tuya Smart Knob?
https://xaviml.github.io/controllerx/controllers/TuYaERS10TZBVKAA/
It seems to connect and I can see the state changes however I get the following error in Zigbee2MQTT:
However if I use the same entity with the Ikea E1744 Smart Knob in ControllerX, it works just fine. Iâm pulling my hair out here! Any help you be GREATLY appreciated! Below is my apps.yaml config:
office_dimmer:
module: controllerx
class: TuYaERS10TZBVKAAZ2MLightController
integration:
listen_to: mqtt
controller: SmartKnob
light: light.switch_office
and here is whatâs in the Z2M config for the Tuya:
'0x003c84fffeb13c00':
friendly_name: SmartKnob
Since Appdaemon was updated to v4.4.0, the templates just stop working.
Going back to v4.2.3 makes it work again, so looks like thereâs some breaking change on Appdaemon, I read the changelog and thereâs nothing mentioning it, but the true is that is doesnât workâŠ
Hi @mama_mia ,
Could you open a bug in the ControllerX GitHub issues and provide:
- appdaemon.yml (exclude sensitive data).
- failing app configuration (from apps.yaml).
- the logs.
- Steps to reproduce the bug.
Thank you,
Xavi M.
Sorry everyone, I have been busy with my personal work and I have not had much time to look to all your messages. I will start look at them soon and reply to all of you.
Thank you for your patience.
Hi @deadphill ,
Color looping is not supported by Z2M Light Controller.
https://xaviml.github.io/controllerx/others/zigbee2mqtt-light-controller/
If you want color looping, you will need to use the regular Light Controller with E2002LightController
Regards,
Xavi M.
Hi @AlexZuiderwijk ,
It seems there is something wrong in the configuration by what the logs shows. If you provide app configuration, it will help me to know what the issue might be.
Thanks,
Xavi M.
Hi @sebpro,
MQTT broker (Mosquitto) documentations says:
ââ"
Option: logins
(optional)
A list of local users that will be created with username and password. You donât need to do this because you can use Home Assistant users too, without any configuration. If a local user is specifically desired:
logins:
- username: user
password: passwd
ââ""
So, if you specified a user and password, you csn use those, otherwise, you can use any Home Assistant user. In case you are using Zigbee2MQTT, you can use the same user you have configured in its configuration.
Regards,
Xavi M.
Hi @Denman2103 ,
I recommend you adding the supported_features flag to your configuration: Controller types - ControllerX
It seems your light does not provide this attribute and it is a mandatory field from HA side. So you will need to provide it through configuration.
Regards,
Xavi M.
Hi @xaviml,
I think I might know what the problem is.
Iâll make some tests later today before opening a bug in ControllerX.
If I can fix it, Iâll open a PR, if not, a but it isâŠ
Hi @mama_mia ,
Apparently, this is an issue with AppDaemon:
- Bug: https://github.com/AppDaemon/appdaemon/issues/1747
- PR: Fix for template/render service by Justihar · Pull Request #1750 · AppDaemon/appdaemon · GitHub
PR is now merged, but we do not know when AppDaemon will release the fix. In the meantime, I am working on patching this fix as part of ControllerX temporarily until AppDaemon releases this fix officially.
I will keep you updated.
Regards,
Xavi M.
Hi @mama_mia ,
I just released fix into ControllerX v4.26.0. I have added a patch as a workaround, you can read more about it in:
- Issue: [BUG] AppDaemon 4.4.X broke templates · Issue #810 · xaviml/controllerx · GitHub
- PR: fix: temporary fix to template rendering by xaviml · Pull Request #811 · xaviml/controllerx · GitHub
EDIT:
I am having problems to use the patch with the AppDaemon addon, I will need to keep looking for a better solution.
Regards,
Xavi M.
Hi @mama_mia again,
I just released ControllerX v4.26.1 with a fix for AppDaemon addon.
Let me know if it works for you.
Regards,
Xavi M.
Just tested it, and itâs working.
Awesome!!
Thankâs!!
Hi @xaviml New Ikea Remote !
ZHA Events
endpoint_id: 1
cluster_id: 6
command: toggle
command: move_with_on_off
args:
- 0
- 255
params:
move_mode: 0
rate: 255
command: move
args:
- 0
- 255
- 0
- 0
args:
- 1
- 255
params:
move_mode: 1
rate: 255
command: move
args:
- 1
- 255
- 0
- 0
command: step
args:
- 1
- 1
- 0
- 0
- 0
params:
step_mode: 1
step_size: 1
transition_time: 0
options_mask: 0
options_override: 0
command: step
args:
- 0
- 1
- 0
- 0
- 0
params:
step_mode: 0
step_size: 1
transition_time: 0
options_mask: 0
options_override: 0
command: shortcut_v1_events
args:
- 1
- 1
params:
shortcut_button: 1
shortcut_event: 1
args:
- 2
- 1
params:
shortcut_button: 2
shortcut_event: 1
New AppDaemon version got release today with the fix for the template rendering. I will remove my patch when I have some more time again.
In case latest version is not working, v4.25.0 can be used since it does not contain the patch, and should work with latest AppDaemon version.
Regards,
Xavi M.
