Hi, I am trying to configure a Ikea Styrbar remote (E2002) with ControllerX. I canāt get the double click āonā to work. I guess there is something wrong with the quoting, but I really donāt know⦠Any help, please?
Here is my app:
Hi, Iām currently trying to setup a Hue dimmer remote to control one of my lights, but I donāt know why it is not triggering. I use Z2M installed on an extra host for Zigbee connectivity and the light is a Tuya bulb. MQTT is also configured and working.
Hi there,
I have been using your script from the time you have posted it. All this time, I have been trying to figure out this little annoyance of mine. That is the light will not turn back on from the off state physically if the light was dimmed to the lowest brightness using a controller (for me are the ikea controllers. E1743, E1524). Although HA shows it is on just the light itself is not lighting up. Toggling from the controller does nothing from the on state. However, if I toggle from HA gui, it works.
To test this further if it is not only the controllers experience this, I use HA gui to turn on/off and toggle between brightness. This seems to work.
My lights are from Ikea (gu10) and E26. Just wondering if you have any inputs.
Hi! Iāve started using ControllerX and itās pretty great! However, I am having trouble getting double presses to work with an Ikea E1812 button. The single press works perfectly, but the double never does anything. I canāt follow the docs exactly as using toggle doesnāt trigger, only "on" does.
I installed appdaemon, how do I get controllerX into it?
Explain very slow because I know nothing about this.
Back story.
Installed Haos on a HP elitebook 1 week ago because I wanted more control.
I must say, itās been hell. The convenience in finished products is something you easy forget.
Well I have lots of ikea products and I thought it would be nice to control them via HAos my self. But Iām leaning towards connecting the ikea controller again and let the Ikea add on do itās thing so I can control my light like Iāve always have been doing with the trĆ„dfri controllers.
Hey @xaviml I see Shelly 1 is not listed as a controller, but I was wondering since the devices probably use the same syntax as the supported Shelly controllers, would it be possible to dim a bulb in deConz with a Shelly 1 mini Gen3 (or similar) via Controller X?
Iāve recently had problems with switches controlling the wrong lights, that and me having a clean up led me to wipe the controllx & Deconz and start fresh⦠now I have my lights and switches in Deconz and I can see the switched in events when I press them, however when I try to link them to a light via Controllerx apps.yaml I get nothing, the light doesnāt changeā¦
Oh Iāve also re-installed Appdeamon and restarted it, as well as rebooted the HA system numerous times.
Hi all,
apologies if this has been already asked but I couldnāt find anything about it.
How can I control multiple speakers (meadia_players) with the same switch?
It works great with one speaker. However if I try to group speakers together and link the configuration to the group it doesnāt work.
Hey. Thanks for reply. I have tried a few combination using these examples and it didnāt work. I tried again after you suggest to used the above and it works. Possibly a typo on my end. This below is working for me. Thanks.
Itās a shame the sensor has bee removed. I have revert back to using the phillps hue bridge for all my lights since using z2m acts weirdly. The light would not turn on if it is turned off below 10% dimmed. If I pair it with phillp hue bridge, it turns back on just fine. I am using all ikea lights.
I just posted over in the github issue relating to the problem of mqtt now using events instead of actions. Just posting here to give a heads up there is an option (at least for now) to continue to use what they call ālegacy action sensorsā. Here it is in case anyone has not seen it:
I have just found an option within zigbee2mqtt that allows for the old action entities to continue to work. You just have to enable it.
Go to zigbee2mqtt, and select settings - home assistant integration and then select the option āHome Assistant legacy action sensorsā. This will then allow your setup to continue to work. How much longer for I have no idea as this might go in the future but I hope it doesnāt. I have multiple actions set for my remotes and reverting to z2m controls means I somehow have to get the devices to work with mqtt which at this moment in time I have no idea about, or somehow work out how to call an event rather than an action and I have no idea if this would even work with controllerx.
Hopefully this helps someone out there⦠Ive been pulling what hair I have left out until I found this in a reddit forum!
